using HA docker installation 2022.8.4 at Pi.
Have created MariaDB server with database and user, is running fine - but after starting HA the tables will not be created.
I get the error:
Error during connection setup: (MySQLdb.OperationalError) (1005, 'Can\'t create table
[DB_Name].
states (errno: 150 "Foreign key constraint is incorrectly formed")')
[SQL:
CREATE TABLE states (
state_id INTEGER NOT NULL AUTO_INCREMENT,
entity_id VARCHAR(255),
state VARCHAR(255),
attributes LONGTEXT,
event_id INTEGER,
last_changed DATETIME(6),
last_updated DATETIME(6),
old_state_id INTEGER,
attributes_id INTEGER,
context_id VARCHAR(36),
context_user_id VARCHAR(36),
context_parent_id VARCHAR(36),
origin_idx SMALLINT,
PRIMARY KEY (state_id),
FOREIGN KEY(event_id) REFERENCES events (event_id) ON DELETE CASCADE,
FOREIGN KEY(old_state_id) REFERENCES states (state_id),
FOREIGN KEY(attributes_id) REFERENCES state_attributes (attributes_id)
)DEFAULT CHARSET=utf8mb4 COLLATE utf8mb4_unicode_ci
What can be the problem?
db_url is ok because some tables will be created:
| Tables_in_[DB_Name] |
| event_data |
| events |
| recorder_runs |
| schema_changes |
4 rows in set (0.001 sec)
Thanks!
Michael
