After a Home Assistant update, subsequent crash and fresh install and restore of snapshot, MariaDB will no longer start properly. All other functions are working. I get the following error message in the MariaDB-log when I manually try to start it.
starting version 3.2.2
Error loading shared library libonig.so.4: No such file or directory (needed by /usr/bin/jq)
Error relocating /usr/bin/jq: onig_foreach_name: symbol not found
Error relocating /usr/bin/jq: onig_region_new: symbol not found
Error relocating /usr/bin/jq: onig_search: symbol not found
Error relocating /usr/bin/jq: onig_error_code_to_str: symbol not found
Error relocating /usr/bin/jq: onig_new: symbol not found
Error relocating /usr/bin/jq: onig_region_free: symbol not found
Error relocating /usr/bin/jq: onig_free: symbol not found
Error relocating /usr/bin/jq: OnigEncodingUTF8: symbol not found
Error relocating /usr/bin/jq: OnigSyntaxPerl_NG: symbol not found
I am running ResonOS 1.3, MariaDB add on 0.2, Versjon 1.3 for the host, 0.101 for the Hass.io supervisor and 0,67 for Home Assistant. I cannot find any entries in the Ha log file that concern MariaDB. I am running on a PI3.
Any advice would be appreciated.
I am new to this forum and I am sorry if I overlooked some guidelines on what info to include in a post, and/or if this should have been posted somewhere else than in the Hass.io category.
I have tried both Google and searching the forum, but unfortunately unable to find an answer. It seems something is not installed correctly (missing file). I have tried to reinstall the Maria DB add-on without luck.
