4:12am is normal. That is the default HA purge being triggered. It happens every night.
This is also happening with PostgreSQL. I dropped the foreign key that is failing and manually deleted the records, since there were a few months worth of records built up.
Dropping the foreign key won’t affect performance but could impact database integrity.
They have provided a possible solution for the problem in the issue earlier mentioned by @brucehvn HERE :
The database has purge!
I Have Hass.IO on Raspberry witn MariaDB add-on.
mysql -u <user_name> -p homeassistant
MariaDB [homeassistant]> SHOW CREATE TABLE states\G
*************************** 1. row ***************************
Table: states
Create Table: CREATE TABLEstates
state_id
int(11) NOT NULL AUTO_INCREMENT,
domain
varchar(64) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
entity_id
varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
state
attributes
text COLLATE utf8mb4_unicode_ci DEFAULT NULL,
event_id
int(11) DEFAULT NULL,
last_changed
datetime DEFAULT NULL,
last_updated
created
old_state_id
PRIMARY KEY (state_id
KEYold_state_id
(old_state_id
KEYix_states_last_updated
(last_updated
KEYix_states_entity_id_last_updated
(entity_id
,last_updated
KEYix_states_event_id
(event_id
CONSTRAINTstates_ibfk_1
FOREIGN KEY (event_id
) REFERENCESevents
(event_id
CONSTRAINTstates_ibfk_2' FOREIGN KEY (
old_state_id) REFERENCES
states(
state_id`)
) ENGINE=InnoDB AUTO_INCREMENT=553 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
After the keyword “Constraint” the ngas have several keys. After that, we make the commands:
MariaDB [homeassistant]> ALTER TABLE states DROP FOREIGN KEY states_ibfk_1;
→ ADD CONSTRAINT states_ibfk_1
→ FOREIGN KEY (event_id)
→ REFERENCES events (event_id)
→ ON DELETE SET NULL;
MariaDB [homeassistant]> ALTER TABLE states DROP FOREIGN KEY states_ibfk_2;
→ ADD CONSTRAINT states_ibfk_2
→ FOREIGN KEY (old_state_id)
→ REFERENCES states (state_id)
MariaDB [homeassistant]> CREATE INDEX ix_states_old_state_id
→ ON states (old_state_id);
after that, I called the recorder.purge service in НА and the data base was compressed!
Well, I had no problem doing manual purges without any database changes by issuing the two following commands in order (I keep 90 days worth of data in my database):
delete from states where created < DATE_ADD("2020-11-27 08:00", INTERVAL -90 DAY);
delete from events where created < DATE_ADD("2020-11-27 08:00", INTERVAL -92 DAY);
I hadn’t done that manual purge since Nov 4, which I think was when I posted this discussion. I went to do the purge today and the data from +90 days ago was already gone, so it appears the automatic purging is working now. I’m running HA 0.118.3 currently.
Error saving events: (MySQLdb._exceptions.IntegrityError) (1452, 'Cannot add or update a child row: a foreign key constraint fails (`hass_db`.`states`, CONSTRAINT `states_ibfk_2` FOREIGN KEY (`old_state_id`) REFERENCES `states` (`state_id`))') [SQL: INSERT INTO states ....
Home assistant core 0.118.3
Any solution here?
Here the pull request. Hope they can merge asap
Did you tried my latest reply?
I’m running 0.117.6 and noticed this morning I had no history data any more. I checked the logs, and it’s full of messages like:
MySQLdb._exceptions.IntegrityError: (1452, 'Cannot add or update a child row: a foreign key constraint fails (`hass`.`states`, CONSTRAINT `states_ibfk_2` FOREIGN KEY (`old_state_id`) REFERENCES `states` (`state_id`))')
I tried executing the commands, and the first set worked, but not the second:
ALTER TABLE states ADD CONSTRAINT states_ibfk_1 FOREIGN KEY (event_id) REFERENCES events (event_id) ON DELETE SET NULL;
ALTER TABLE states ADD CONSTRAINT states_ibfk_2 FOREIGN KEY (old_state_id) REFERENCES states (state_id) ON DELETE SET NULL;
I get:
Cannot add or update a child row: a foreign key constraint fails (`hass`.`#sql-241_2dd78`, CONSTRAINT `states_ibfk_2` FOREIGN KEY (`old_state_id`) REFERENCES `states` (`state_id`) ON DELETE SET NULL)
For ref, when I do a SHOW CREATE TABLE states
, I get:
CREATE TABLE `states` (
`state_id` int(11) NOT NULL AUTO_INCREMENT,
`domain` varchar(64) DEFAULT NULL,
`entity_id` varchar(255) DEFAULT NULL,
`state` varchar(255) DEFAULT NULL,
`attributes` text DEFAULT NULL,
`event_id` int(11) DEFAULT NULL,
`last_changed` datetime DEFAULT NULL,
`last_updated` datetime DEFAULT NULL,
`created` datetime DEFAULT NULL,
`old_state_id` int(11) DEFAULT NULL,
PRIMARY KEY (`state_id`),
KEY `old_state_id` (`old_state_id`),
KEY `ix_states_entity_id_last_updated` (`entity_id`,`last_updated`),
KEY `ix_states_event_id` (`event_id`),
KEY `ix_states_last_updated` (`last_updated`),
CONSTRAINT `states_ibfk_1` FOREIGN KEY (`event_id`) REFERENCES `events` (`event_id`) ON DELETE SET NULL
) ENGINE=InnoDB AUTO_INCREMENT=324643 DEFAULT CHARSET=utf8
From your Show Table, it only states states_ibfk_1
there is no states_ibfk_2
Isn’t that because I already executed ALTER TABLE states DROP FOREIGN KEY states_ibfk_2;
and the command that would add back states_ibfk_2
is failing?
The problem is the foreign key states_ibfk_2. This ist set for the column old_state_id, wich refereces to state_id. So you can’t delete a row, with state_id stored in old_state_id. I don’t know, why they do that. But if you delete the foreign key states_ibfk_2, then it will run well.
Still this issue, and more : history stops functionning almost every night. I restart Home Assistant and recording functionnality is back.
I have the same problem. MySQL recorder stops working every night. Testing this patch now.
I’m running MariaDB. Will this self-correct at the next release?
I have the same error. Running MariaDB on local SSD on RPi4. Where do I go to be able to use CLI in order to send the following command?
Is that actually what I am supposed to do? Is the correct procedure for my setup the one at https://github.com/home-assistant/core/issues/42402#issuecomment-729327643 ?
If you are using home assistant you can install the phpMyAdmin addon, once inside select your homeassistant database, in the sql tab copy the following:
ALTER TABLE states
ON DELETE SET NULL;
ALTER TABLE states
ON DELETE SET NULL;
and press continue
Once the processes are finished, go to your home assistant and run a manual purge from the services tab
I might have made a mistake after my post and prior to reading your post. I already had the phpMyAdmin addon and I sent two individual commands thinking maybe the others were supposed to be responses.
I pasted
then clicked Go
then I pasted
Then I clicked Go
Then I went to Developer Tool -> Service and used recorder.purge
Now when I go back to phpMyAdmin I get error code: 524 when I send
ALTER TABLE states
ON DELETE SET NULL;
Is there something I need to do to correct what I did wrong?
edit: I gest there error code: 524 was because it wasn’t getting a response at all. I kept trying and now I get
#1005 - Can't create table `homeassistant`.`states` (errno: 121 "Duplicate key on write or update") (Details…)
then I click on Details and it says it already exists. So now I wonder if the command went through once before but I never saw the response.
I’m sorry, I wouldn’t know what to tell you. In fact, I thought I had fixed mine, but I just realized that it’s failing too.
I guess there will be waiting for an update of the addon to come out
EDIT:
It seems to be working, it only gives an error when doing a manual purge, with the automatic purge everything seems to work correctly
Upgraded to 2020.12.0
WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 9
Purge is back again
I updated to 2020.12 this morning and watched my DB go from 1.3Gb to 300mb!
Yay! Purge is working again!
+1 Seems working fine after the upgrade.
