I’m running the 0.117.3 hassio with the mariadb add-on. I was trying to execute a purge service call and it didn’t appear to work. I looked in the log and I see these errors:
2020-11-04 21:11:58 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (MySQLdb._exceptions.IntegrityError) (1451, 'Cannot delete or update a parent row: a foreign key constraint fails (`homeassistant`.`states`, CONSTRAINT `states_ibfk_1` FOREIGN KEY (`event_id`) REFERENCES `events` (`event_id`))')
[SQL: DELETE FROM events WHERE events.time_fired < %s]
[parameters: (datetime.datetime(2020, 7, 8, 7, 26, 53, tzinfo=<UTC>),)]
(Background on this error at: http://sqlalche.me/e/13/gkpj)
2020-11-04 21:11:59 WARNING (Recorder) [homeassistant.components.recorder.purge] Error purging history: (MySQLdb._exceptions.IntegrityError) (1451, 'Cannot delete or update a parent row: a foreign key constraint fails (`homeassistant`.`states`, CONSTRAINT `states_ibfk_1` FOREIGN KEY (`event_id`) REFERENCES `events` (`event_id`))')
It looks like maybe it’s trying to delete from the events table, but it needs to delete from the states table first to avoid a foreign key error. I’ve successfully purged manually by deleting from the states table first.
