MariaDB stopped saving history
Good afternoon… I’m using mariadb to save my history, and today around 12:30 UTC, it stopped saving. When I restart HA, it updates the database once and stops again.
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:577
Integration: Recorder (documentation, issues)
First occurred: 15:33:12 (1 occurrences)
Last logged: 15:33:12
Ended unfinished session (id=696 from 2023-02-26 14:26:58)
I have this error in the logs that I don’t know if it’s related.
someone can help me? Thanks
Is your db still healthy? Can you login with sql tool?
Did you upgrade recently? Not sure how youre running mariadb but There was a breaking change in the Feb release that caused older versions of mariadb to stop working.
10.6.10 should be fine. Does phpadmin function still with data querying too?
I stopped the mariadb server and turned it back on and it was fine. never happened to me. thanks
