I’m trying to use mariadb on my synology that has mariadb 10.3.29 installed.
But the recorder keeps showing up with:
Database mariadb is not supported; Home Assistant supports MariaDB ≥ 10.3, MySQL ≥ 8.0, PostgreSQL ≥ 12, SQLite ≥ 3.31.0. Starting with Home Assistant 2022.6 this prevents the recorder from starting. Please migrate your database to a supported software
For now I moved to postgressql in docker container - might as well use the better DB
The error message about mariadb is weird though mariadb >= 10.3 I read as 10.3 and above is supported. If 10.3 was not supported why is it not then saying mariadb >= 10.4 or mariab > 10.3 ?
I’m getting the same errormessage when using mariadb 11.2.
A bit later: in db_url I needed to put mysql in front of the connectionstring instead of mariadb so then it worked but still had some issues and my energy-dashboard totally got messed up so I reverted back to sqlite. Might keep my mariadb as a backup and fill it occassionally.
