Thank you. Those results were along the lines that I had found previously
I could not see anything that allows me to change the font colour or highlighting the text in the dashboard though. (Looked in the documentation as well)
If you wish for a Dashboard solution then look at auto-entities.
I have a veiw on my system dashboard that has two columns for Automations, “Running Automations” and “Idle Automations”. See below for full example.
Your auto-entities for states unavailable or unknown would start with…
Yaml Code for my Idle Automations (running is same except for tite and current: 1. I use options: to use the entities row as custom:multiple-entities-row which would allow you to do most variants of display including color, though for me I am including last_triggered as a debug info for if an automation has not run when expected.
