Markdown in blueprint description
Is it at all possible to have Markdown in a blueprint description that is both readable and renders as intended? I cannot figure it out.
If I use literal YAML multiline mode (|), all linebreaks are preserved which obviously is not desirable in paragraphs:
description: |-
  # Lorem ipsum dolor sit amet
  Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt
  ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco
  laboris nisi ut aliquip ex ea commodo consequat. Duis aute  irure dolor in reprehenderit in
  voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat
  non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
  lorem_ipsum_dolor:
    sit_amet_consectetur: Sed do eiusmod tempor
    incididunt_ut_labore: Et dolore magna aliqua
If I use folded YAML multiline mode (>), whitespace is folded but that includes between paragraphs (also note first line of code block disappears):
description: >-
  lorem_ipsum_dolor:
The only way I can preserve rendered intent is to use literal mode but never use linebreaks in paragraphs, which makes the blueprint harder to read/write:
description: |-
  Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
  lorem_ipsum_dolor:
Is there another mode which behaves as Markdown is clearly designed to operate, where whitespace within paragraphs are folded but not between paragraphs and never within code blocks etc.?
