Markdown link isn't working for me
I’m trying to insert a hyperlink in a markdown card, but failing.
What I see:
My markdown code:
  - type: conditional
    conditions:
      - condition: state
        entity: binary_sensor.192_168_0_208
        state: 'on'
    card:
      type: markdown
      content: ' <p>OctoPi OS is running.</p>
         <p>Take care to properly shut down the server <strong>before</strong> turning off the power.</p>
         <p>There is an option in OctoPrint to shutdown the OS:
         <p> [OctoPrint Server UI](https://192.168.0.208)
         <p>https://192.168.0.208
         <p>(https://192.168.0.208)
         <p>You can also ssh into the OS then issue a shutdown command.
         <ul><pre>$ssh [email protected]</pre></ul>
         <p>There is a safe shutdown button on the board as well.</p> '
You’re mixing HTML-style (eg <p>) and markdown-style together (eg [x](y)) - not that I realised you could do that. Leaving a blank line seems to ‘reset’ it, or use an <a> tag, or just use markdown only instead:
  - type: markdown
    content: |
      <p>There is an option in OctoPrint to shutdown the OS:</p>
  - type: markdown
    content: |
      <a href="https://192.168.0.208">OctoPrint Server UI</a>
  - type: markdown
    content: |
      OctoPi OS is running.\
      Take care to properly shut down the server **before** turning off the power.\
      There is an option in OctoPrint to shutdown the OS:\
Thanks, @michaelblight .
That did it!!
