Martin Jerry Pre-Flashed Tasmota 3-way trailing edge dimmer
I recently installed a Martin Jerry pre-flashed Tasmota 3-Way Trailing edge dimmer switch. This switch has a potentiometer on it to set the low end dimer o prevent flicker. I have been trying to get this switch to behave as expected but it doesn’t dime correctly – it does not seem to have a smooth “linear” dimming range. I have tried several different DimmerRanges through the Tasmota console (dimmerrange 1,255, or 48,234, etc.). While it seems to make a difference, I haven’t found a range that works reliably. Looking for some guidance please.
