I can see clearly that with the MQTT event stream all the events are being passed through the MQTT.
I decided to run a secondary HA instance for the TTS.
So on master i have set a rule firing like
- service: mqtt.publish
topic: "exchange"
payload: "kidshumidity"
And on the slave
platform: mqtt
topic: "exchange"
The problem is that on slave the rule like this never reads the sensor value - only the text. I thought that MQTT stream is suppose to pass those values to the slave… Any options on fixing? What might be wrong? Or the only option is to setup thos sensor values on slave as well?
message: ' Temperature {{ states.sensor.mys_zal_temp.state }} Humidity {{ states.sensor.mys_zal_hum.state }} '
