Hello, i am trying to set up a master/slave configuration with an Ubuntu-server as the master and a Raspberry Pi3(raspbian) with Razberry as a simple Z-wave controller.
On both machines i have followed the installation guides from the HASS website, with the virtualenv configuration.
I also tried to set up master/slave according to the guide “Multiple Instances” from the HASS website, using the script suggested there with the IP pointing to the master:
Script: (slave.py)
#!/srv/homeassistant/bin/python3
import homeassistant.remote as remote
import homeassistant.bootstrap as bootstrap
# Location of the Master API: host, password, port.
# Password and port are optional.
remote_api = remote.API("192.168.111.117")
# Initialize slave
hass = remote.HomeAssistant(remote_api)
# To add an interface to the slave on localhost:8123
bootstrap.setup_component(hass, 'frontend')
hass.start()
hass.block_till_stopped()
When i run it i get the error message:
(homeassistant) homeassistant@raspberrypi:/srv/homeassistant $ ./slave.py
File "./slave.py", line 11, in <module>
AttributeError: 'module' object has no attribute 'HomeAssistant'
How can i fix this?
