Hello All - just started converting from smartthings to home assistant. When I change the friendly name of a device, it doesn’t change the entity ID to conform, so if I go into the YAML editor for automations its hard to know which device is which. I know I can go in and manually edit the entity ID of each sensor under the device, but wanted to know if there was a quick way to match it.
Note I’m only looking to do this once at the initial adoption, I know if I change entity IDs after I start setting up automations I’d mess it up so I’m only doing this once. For Zigbee devices, at adoption I have the option of putting in a custom name and that will propagate to each sensor. But Zwave adoption automatically puts the device into the system before I can change the name, and changing the friendly name afterwards don’t conform the entity ID.
Thanks,
