Match multiple Initial states of an AC
I found this piece of code in the cookbook and I find it very useful but I need to change the value ‘on’ of the state variable with something like:
"every state different from ‘Off’ ",
since the variabile “state” could has different values.
p.s: I know this is a switch but I am using the climate itself.
#         Air Conditionar Self Shutdown            #
- id: AC_Self_Shut
  alias: AC Self Shutdown - Heat
    - platform: state
      entity_id:
        - switch.air_conditioner__heat_30
      state: 'on'
      for: '02:01:00'
    - service: switch.turn_off
      data_template:
        entity_id: " {{ trigger.entity_id }} "
    - service: notify.homenicoassistant_bot
      data_template:
        message: >
          "{{ trigger.to_state.attributes.friendly_name }} just changed from {{ trigger.to_state.state }}
          to {{ trigger.from_state.state }} - AC Selfshutdown Automation - Heat 30 Mode OFF"
You can specify each state as a different trigger
- id: AC_Self_Shut
    - platform: state
      entity_id:
      to: 'off'
      for: '02:01:00'
    - platform: state
      entity_id:
      to: 'unavailable'
      for: '02:01:00'
    - platform: state
      entity_id:
      to: 'disconnected'
      for: '02:01:00'
      data_template:
      data_template:
        message: >
If one of the states is triggered, automation is set to run.
Hope this helps.
