Hi, I’ve created a material dark theme. It should be easily changeable by just changing the hex code of the inital colour. If you end up with random pink colour, it is the colour I have set to show when I couldn’t find where it is displayed in my home assistant instance. It looks pretty good and should be easy to change if you don’t like the shades. It looks good on my computer as well but i don’t have any screenshots of it.
material_dark_green:
light_green: "#08a8a5"
dark_green: "#017775"
dark_grey: "#232326"
light_grey: "#344249"
red: "#d10404"
yellow: "#fffa0c"
white: "#f7f7f7"
pink: "#ff0090"
#Top bar, activate text on script, selected icon on home assistant menu, top panel of media players, text in config page, text on developer tools states page, mqtt publish text, logbook text
primary-color: "var(--light_green)"
# divider on dev tools info page
light-primary-color: "var(--red)"
# some hyperlinked text
dark-primary-color: "var(--red)"
# not sure where used
text-primary-color: "var(--pink)"
# main background, top of side panel
primary-background-color: "var(--dark_grey)"
sidebar-text_-_background: "var(--pink)"
# card background colour, part of media player background
paper-card-background-color: "var(--light_grey)"
# mqtt pubish header and thats it
paper-card-header-color: "var(--white)"
# main background colour of states page
secondary-background-color: "var(--dark_grey)"
# most of the text used
primary-text-color: "var(--white)"
#secondary pieces of text
secondary-text-color: "var(--white)"
#main background of side panel
paper-listbox-background-color: "var(--light_grey)"
#not sure where used
paper-toggle-button-checked-ink-color: "var(--pink)"
#switch colour when on
paper-toggle-button-checked-button-color: "var(--yellow)"
#Backgroud of switch/toggle when on
paper-toggle-button-checked-bar-color: "var(--yellow)"
#slide knob on brightness/volumes when not 0
paper-slider-knob-color: "var(--yellow)"
#slide knob on brightness/volumes when 0
paper-slider-knob-start-color: "var(--red)"
#don't know where used
paper-slider-pin-color: "var(--pink)"
#colour of brightness/volume slider line in used portion
paper-slider-active-color: "var(--yellow)"
paper-slider-secondary-color: "var(--pink)"
# background of brightness/volume slider line not used portion
paper-slider-container-color: "var(--red)"
paper-progress-secondary-color: "var(--pink)"
#background of theme selection toggle tiny use
paper-item-selected_-_background-color: "var(--light_green)"
#text, not sure which one "var(--white)"
paper-item-icon_-_color: "var(--pink)"
# icon on state page when off
paper-item-icon-color: "var(--dark_green)"
#states icon when active
paper-item-icon-active-color: "var(--yellow)"
#colour of switch toggle when off, icon on selected page of menu
paper-grey-50: "var(--light_green)"
#background of selected screen on menu "var(--light_green)"
paper-grey-200: "var(--dark_green)"
#Backgound of label icon
label-badge-background-color: "var(--light_grey)"
#colour of text in label icon
label-badge-text-color: "var(--white)"
#colour of edge of sensor labels
label-badge-red: "var(--red)"
label-badge-blue: "var(--pink)"
label-badge-green: "var(--pink)"
label-badge-yellow: "var(--pink)"
label-badge-grey: "var(--pink)"
# Row 1 on entities page
table-row-background-color: "var(--light_grey)"
# row 2 on entities page
table-row-alternative-background-color: "var(--dark_grey)"
