I have created a nice dashboard and used a lot of the material design icons for the window shutters. I had icons for 33% open, 50% open, 66% open, fully open. After the latest update, those icons are all gone.
I checked on the material design page and could not find them anymore. Anybody facing the same issue? how likely is it to get those icons back?
Any recommendation for other icons, that might fit my dashboard? (roof top window shutters and vertical shutters…)
Have you ‘visually’ searched for these icons? Quite frequently, to make the whole set naming consistant, they change the name of some icons to something completely different, but do not remove them from collection…
ah, sorry, I was typing on my phone. I know, how to reference icons on the material design library. I tried to find the names of those icons, that I am missing. They seem to have been removed from my config during the update. (docker container update)
How do you reference icons, if you put them locally? What are the requirements on local icons?
jchh
(my username is my initials (and my first name isn't John))
10
I do it 'normally` eg:
icon: mdi:window-shutter
and it works fine. I have no clue why it isn’t working for you. Have you cleared your cache?
is working fine for me as well. If you read my first post: there have been other shutter-icons, that are missing now. My question is about those icons.
those were never in MDI. maybe you had them installed via one of the available custom icon sets?
btw, from the screenshot: what cards are those? maybe mushroom, or minimalist? be sure to update those too, as icon handling has changed in. between HA updates, and the custom cards need to update their syntax for that
I use these,
and my custom_icons CC, just drop them in the folder and be done with it:
thank you for that hint. I usually update HA one a month and usually, I take a very close look at the release notes. Especially the breaking changes… well, this time, I did not.
I just updated my Mushroom add-in and now, all of the icons are back. Well, not the ones, I remember, but that might be because I touched many things in my dashboard in the last couple of days.
