Math operations with a sensor value
I’d like to define a template sensor which is calculated.
a scaling factor is used to manipulate it, and therefore I need to use a “power” function.
here my sample, which doesn’t work:
template:
  - sensor:
      - name: "LeistungMPP1"
        unit_of_measurement: "W"
        state: >
          {% set mpp1 = states('sensor.power_MPP1') * pow(10, states('sensor.power_sunssf')) | float %}
          {{ mpp1 }}
sensor.power_MPP1 and sensor.power_sunssf are available. sensor.power_sunssf can be -10 to +10
 {% set mpp1 = states('sensor.power_MPP1') * 10 ** states('sensor.power_sunssf') | float %}
sorry. it doesn’t work either…
even if I just try to use:
{% set mpp1 = states('sensor.power_MPP1') * 10 ** 1 | float %}
the state is unavailable.
same for:
{% set mpp1 = states('sensor.power_MPP1') * 10 | float %}
it works only that way:
{% set mpp1 = states('sensor.power_MPP1') | float %}
if pow is a correct syntax then this should work. (or use Tom’s syntax but add the | float)
You need to convert each state from string to float before doing the math.
template:
  - sensor:
        state: >
          {% set mpp1 = states('sensor.power_MPP1') | float * 10 ** states('sensor.power_sunssf') | float  %}
          {{ mpp1 }}
It’s not. See:
https://jinja.palletsprojects.com/en/3.1.x/templates/#math
But yeah, I mist that first float filter.
thanks! that worked!
