Matrix integration matrix.org only? any frei.chat users?
Hi there,
I am struggling to get the Matrix integration in core 2024.2.1 running.
My configuration looks like:
matrix:
  homeserver: https://frei.chat
  username: "@[xxx]:frei.chat"
  password: !secret [xxxpw]
  rooms:
    - "#[xxx.yyy]:frei.chat"
notify:
  - name: matrix_notify
    platform: matrix
    default_room: "#[xxx.yyy]:frei.chat"
“[xxx]” is a placeholder. There are no square brackets in my names but yes, my room name contains a dot.
All what I get in the logs is the message:
Logger: nio.responses
Source: components/matrix/__init__.py:395
First occurred: 3:17:54 PM (1 occurrences)
Last logged: 3:17:54 PM
Error validating response: 'user_id' is a required property
I had a look in core/homeassistant/components/matrix/__init__.py at 6aae44dbb3efd8f323ace5075b59e703cef24fe3 · home-assistant/core · GitHub but cannot really get a clue.
Probably 'user_id' is a required property is a response of frei.chat which cannot be parsed? But frei.chat is using standard Matrix server.
Any hints and tips welcome.
I’m facing exactly the same problem and also don’t have any clue.
I can confirm that I don’t get that error with a matrix.org account.
@viegelinsch I got it running with matrix.org
But the documentation at Matrix - Home Assistant is misleading:
I got complains with the automation.
Instead of
- alias: "React to !testword"
    triggers:
      - trigger: event
        event_type: matrix_command
        event_data:
          command: testword
    actions:
      - action: notify.matrix_notify
          message: "It looks like you wrote !testword"
I had to write
      - platform: event
        event_data:
          command: testword
    actions:
In addition, it should be mentioned with big letters that encrypted rooms are not working.
