Hi everyone!
Complete newbie here… starting my journey playing around with things and, as one of my first projects, I’ve been trying to set up a matrix keypad using a D1 Mini.
(Haven’t yet gotten to playing with key collector - just trying to get individual keys to show up as binary sensors for now.)
Currently, all the entities show up as “Unknown” in HA and I’m getting stuck with figuring out where I went wrong.
Before I tear things apart physically to rule out if I maybe connected something poorly somewhere, I thought I might see if any of you might spot something else I may have messed up on.
I’ve been using this as a guide:
Keypad is connected to the D1 Mini like this:
Here’s where I’m at configuration-wise:
esphome:
friendly_name: Keypad Panel
esp8266:
board: d1_mini
logger:
api:
encryption:
key: [redacted]
ota:
password: [redacted]
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Keypad-Panel Fallback Hotspot"
captive_portal:
matrix_keypad:
rows:
- pin: GPIO5
- pin: GPIO4
- pin: GPIO0
- pin: GPIO2
columns:
- pin: GPIO14
- pin: GPIO12
- pin: GPIO13
- pin: GPIO15
keys: "123A456B789C*0#D"
has_diodes: false
binary_sensor:
- platform: matrix_keypad
keypad_id: mykeypad
row: 0
col: 0
keypad_id: mykeypad
row: 1
col: 0
keypad_id: mykeypad
row: 2
col: 0
keypad_id: mykeypad
row: 3
col: 0
keypad_id: mykeypad
row: 0
col: 1
keypad_id: mykeypad
row: 1
col: 1
keypad_id: mykeypad
row: 2
col: 1
keypad_id: mykeypad
row: 3
col: 1
keypad_id: mykeypad
row: 0
col: 2
keypad_id: mykeypad
row: 1
col: 2
keypad_id: mykeypad
row: 2
col: 2
keypad_id: mykeypad
row: 3
col: 2
keypad_id: mykeypad
row: 0
col: 3
keypad_id: mykeypad
row: 1
col: 3
keypad_id: mykeypad
row: 2
col: 3
keypad_id: mykeypad
row: 3
col: 3
and here are the logs w/ install over wifi:
INFO ESPHome 2023.12.5
INFO Reading configuration /config/esphome/keypad-panel.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing keypad-panel (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
RAM: [==== ] 42.1% (used 34456 bytes from 81920 bytes)
Flash: [===== ] 47.1% (used 492221 bytes from 1044464 bytes)
========================= [SUCCESS] Took 1.57 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of keypad-panel.local
INFO -> [redacted]
INFO Uploading /data/build/keypad-panel/.pioenvs/keypad-panel/firmware.bin (496368 bytes)
INFO Compressed to 348192 bytes
Uploading: [============================================================] 100% Done...
INFO Upload took 3.85 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from keypad-panel.local using esphome API
WARNING Can't connect to ESPHome API for keypad-panel.local: Error resolving IP address: [Errno -5] No address associated with hostname (APIConnectionError)
INFO Trying to connect to keypad-panel.local in the background
INFO Successfully connected to keypad-panel @ [redacted] in 0.005s
INFO Successful handshake with keypad-panel @ [redacted] in 2.887s
[14:04:57][I][app:102]: ESPHome version 2023.12.5 compiled on Jan 4 2024, 13:21:41
[14:04:57][C][wifi:573]: WiFi:
[14:04:57][C][wifi:405]: Local MAC: [redacted]
[14:04:57][C][wifi:410]: SSID: [redacted]
[14:04:57][C][wifi:411]: IP Address: [redacted]
[14:04:57][C][wifi:412]: BSSID: [redacted]
[14:04:57][C][wifi:414]: Hostname: 'keypad-panel'
[14:04:57][C][wifi:416]: Signal strength: -64 dB ▂▄▆█
[14:04:57][C][wifi:420]: Channel: 2
[14:04:57][C][wifi:421]: Subnet: 255.255.255.0
[14:04:57][C][wifi:422]: Gateway: [redacted]
[14:04:57][C][wifi:423]: DNS1: [redacted]
[14:04:57][C][wifi:424]: DNS2: [redacted]
[14:04:57][C][logger:443]: Logger:
[14:04:57][C][logger:444]: Level: DEBUG
[14:04:57][C][logger:445]: Log Baud Rate: 115200
[14:04:57][C][logger:447]: Hardware UART: UART0
[14:04:57][C][matrix_keypad:095]: Matrix Keypad:
[14:04:57][C][matrix_keypad:096]: Rows:
[14:04:57][C][matrix_keypad:098]: Pin: GPIO5
[14:04:57][C][matrix_keypad:098]: Pin: GPIO4
[14:04:57][C][matrix_keypad:098]: Pin: GPIO0
[14:04:57][C][matrix_keypad:098]: Pin: GPIO2
[14:04:57][C][matrix_keypad:100]: Cols:
[14:04:57][C][matrix_keypad:102]: Pin: GPIO14
[14:04:57][C][matrix_keypad:102]: Pin: GPIO12
[14:04:57][C][matrix_keypad:102]: Pin: GPIO13
[14:04:57][C][matrix_keypad:102]: Pin: GPIO15
[14:04:57][C][captive_portal:088]: Captive Portal:
[14:04:57][C][mdns:115]: mDNS:
[14:04:57][C][mdns:116]: Hostname: keypad-panel
[14:04:57][C][ota:097]: Over-The-Air Updates:
[14:04:57][C][ota:098]: Address: keypad-panel.local:8266
[14:04:57][C][ota:101]: Using Password.
[14:04:57][C][api:139]: API Server:
[14:04:57][C][api:140]: Address: keypad-panel.local:6053
[14:04:57][C][api:142]: Using noise encryption: YES
[14:04:59][D][api:102]: Accepted [redacted]
[14:04:59][W][component:214]: Component api took a long time for an operation (0.29 s).
[14:04:59][W][component:215]: Components should block for at most 20-30ms.
[14:05:00][D][api.connection:1121]: Home Assistant 2024.1.0 ([redacted]): Connected successfully
Any thoughts would be immensely appreciated!
