2020-01-22 14:19:52 ERROR (MainThread) [homeassistant.setup] Error during setup of component matrix
File "/usr/src/homeassistant/homeassistant/setup.py", line 174, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File "/usr/src/homeassistant/homeassistant/components/matrix/__init__.py", line 88, in setup
config[CONF_COMMANDS],
File "/usr/src/homeassistant/homeassistant/components/matrix/__init__.py", line 161, in __init__
self._client = self._login()
File "/usr/src/homeassistant/homeassistant/components/matrix/__init__.py", line 291, in _login
client = self._login_by_token()
File "/usr/src/homeassistant/homeassistant/components/matrix/__init__.py", line 324, in _login_by_token
valid_cert_check=self._verify_tls,
File "/usr/local/lib/python3.7/site-packages/matrix_client/client.py", line 152, in __init__
self._sync()
File "/usr/local/lib/python3.7/site-packages/matrix_client/client.py", line 581, in _sync
room._process_state_event(event)
File "/usr/local/lib/python3.7/site-packages/matrix_client/room.py", line 640, in _process_state_event
self.guest_access = econtent["guest_access"] == "can_join"
KeyError: 'guest_access'
After a lot of trail and error figured out that sins upgrade #30027 for me, this integration only works wit the matrix.org server and not my home server (synapse v 1.10.0).
I loaded the old config files form before the upgrade in the /custom_components/ folder and [matrix] integration works again for me. Files I loaded: Github [#29392]
I’ve got the same error with a matrix.org account I try to set up:
File "/usr/src/homeassistant/homeassistant/components/matrix/__init__.py", line 304, in _login
client = self._login_by_password()
File "/usr/src/homeassistant/homeassistant/components/matrix/__init__.py", line 333, in _login_by_password
_client.login_with_password(self._mx_id, self._password)
File "/usr/local/lib/python3.7/site-packages/matrix_client/client.py", line 249, in login_with_password
return self.login(username, password, limit, sync=True)
File "/usr/local/lib/python3.7/site-packages/matrix_client/client.py", line 280, in login
self._sync()
I would like try your method (use old config files) but I’m not able to correctly write my configuration.yaml.
Will you please show me how to you refer to the custom component in your configuration.yaml ?
your configuration.yaml says exacly the same as normal.
The only thing you do is load this folder in the config\custom_components folder. When you reboot home assistant it will use these to load the matrix component.
It seems I can connect now to matrix but I’ve got a new error:
Logger: custom_components.matrix
Source: custom_components/matrix/__init__.py:182
First occurred: 17:34:25 (1 occurrences)
Last logged: 17:34:25
Could not join room - "!myroomid:matrix.org": 400: {"errcode":"M_UNKNOWN","error":"Â - \"!myroomid:matrix.org\" was not legal room ID or room alias"}
Yes, it has access.
I don’t know what happened but now I didn’t have the error message !
So strange !
But the bot seems to not work, I can’t have event from a command written in the room.
I work at the same time with node-red-contrib-matrix and It works well ! I can send and receive message from the room.
Should the command to be written in the room by an other account ?
Because in the node-red-contrib-matrix I had to uncheck “Filter events sent by self” to be able to receive my own messages.
You might want to try again @Mathijs. My integration also wasn’t working and decided to test it again running 2021.4.3 and am able to successfully send messages from HA.
