Matter Add-on does not start
Hello everyone,
I have installed the Matter add-on and tried to start it, unfortunately it does not start and the log shows the following:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
Add-on: Matter Server
Matter WebSocket Server for Home Assistant Matter support.
Add-on version: 5.2.0
You are running the latest version of this add-on.
System: Debian GNU/Linux 11 (bullseye) (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.2.3
Home Assistant Supervisor: 2024.02.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service matter-server: starting
s6-rc: info: service matter-server successfully started
s6-rc: info: service legacy-services: starting
[17:37:43] INFO: Starting Matter Server…
s6-rc: info: service legacy-services successfully started
[17:37:44] FATAL: No primary network interface found!
[16:37:44] WARNING: matter-server service exited with code 1 (by signal 0).
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service matter-server: stopping
s6-rc: info: service matter-server successfully stopped
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Can anyone help me with this?
Matter on anything other than HAOS or HA Supervised is pretty much a alpha release.
I have no clue what is wrong with your setup, but you need for sure a working IPv6 network (a public IPv6 IP is not needed. Just a fe80, which is auto-generated) and you need to make sure that HA supervisor have full control of the docker management.
I think this is the problem.
Doing a little research to try and help out… the Matter AddOn and (probably a few other AddOns as well) rely on calling a Supervisor API to get the primary network interface.
So most likely its a Supervisor problem, or perhaps OS-Agent. It looks like you are running an “HA Supervised” installation (which I know very little about), and here are the requirements. The one thing that stands out, is that Debian Linux 11 is no longer supported.
Thanks for the advice!
It was ultimately the IPv6 setting of the Raspberry Pi. I reinstalled the Home Assistant OS and since then Matter has been running without any problems.
I have the same problem after restoring an update on a new RP5.
Could you please specify exactly what steps I should take in order to solve the problem? Just reinstall Home Assistant OS completely? Or could the issue be linked to the backup coming from a RP3 originally?
Thanks!
I had the same issue “ No primary network interface found!”. So I opened the network setting in Home Assistant and disabled the IPv6 and updated the IPv4, and they issue gone.
