Matter Add-On won't install
Hi everybody!
I am all pretty new to this and learning as I go.
I wanted to install the Matter addo-on to my HA install, which runs on a Pi 5 with version 2024.9.1 running.
Whenever I want to install the add-on, I get an infinitely spinning wheel.
When I check the Supervisor logs, I see this message:
e[32m2024-09-13 13:17:03.106 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-matter-server with tag 6.5.1.e[0m
e[31m2024-09-13 13:17:03.131 ERROR (MainThread) [supervisor.docker.interface] Can’t install homeassistant/aarch64-addon-matter-server:6.5.1: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=6.5.1&fromImage=homeassistant%2Faarch64-addon-matter-server&platform=linux%2Farm64: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution”)e[0m
I tried to figure out what I could do, restarted HA and the Pi itself, reverting to an previous version etc but no luck so far.
I PRESUME it is network related, but I have no idea how to resolve that. I even gave the Pi a direct line out my home network and it is reachable from outside> But since I am new, I am probably missing something obvious here.
Any help is much appreciated!
Have a nice day!
Well, never mind.
I created a loop by accident in my network which screwed with my internal DNS resolve.
Case closed!
Thanks for the update.
We actually plan to improve insights in what exactly is wrong. To learn from real world cases: In your case, in what way was your DNS misconfigured?
I resolve some sites internally, mostly goverment ones or work ones or those that are prone to phishing and such.
As a result I have an internal DNS servers that manages those so that I do not have to rely on the public ones.
I wrongly patched my Pi so that it only had the internal DNS server and was unable to reach the external/public DNS servers.
