I am brand new to the world of home assistant / smart home!
But I have so problems with the Matter Add-On (Matter Server).
I try to install it but immediately comes the message that it can not be started.
If I try it by hand nothing happens either.
I can read a lot in the log, but I don’t see anything that jumps out at me… that’s it.
I installed everything with HAOS on a Zotac x86 machine.
Here are the last lines of the log/protocol:
2023-10-11 07:36:53 core-matter-server matter_server.server.client_handler[126] DEBUG [140550615952976] Connected from ::1
2023-10-11 07:36:53 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597255760] Connected from 127.0.0.1
2023-10-11 07:36:53 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597255760] Received: {
"message_id": "c2e0ff0d08d64b50b4c86a202d3f580e",
"command": "start_listening",
"args": null
2023-10-11 07:36:53 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597255760] Received CommandMessage(message_id='c2e0ff0d08d64b50b4c86a202d3f580e', command='start_listening', args=None)
2023-10-11 07:36:53 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597255760] Handling command start_listening
2023-10-11 07:38:16 core-matter-server matter_server.server.client_handler[126] WARNING [140550615952976] Disconnected: Received non-Text message.
2023-10-11 08:05:48 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597329040] Connected from ::1
2023-10-11 08:05:48 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597255760] Unsubscribed from events
2023-10-11 08:05:48 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597255760] Disconnected
2023-10-11 08:05:48 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597330704] Connected from 127.0.0.1
2023-10-11 08:05:48 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597330704] Received: {
"message_id": "42114f2c9b9548168315e6190e95bcd9",
"args": null
2023-10-11 08:05:48 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597330704] Received CommandMessage(message_id='42114f2c9b9548168315e6190e95bcd9', command='start_listening', args=None)
2023-10-11 08:05:48 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597330704] Handling command start_listening
2023-10-11 08:05:57 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597330704] Received: {
"message_id": "ce1204a4d98649ef8a46767d31437c54",
"command": "diagnostics",
"args": {}
2023-10-11 08:05:57 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597330704] Received CommandMessage(message_id='ce1204a4d98649ef8a46767d31437c54', command='diagnostics', args={})
2023-10-11 08:05:57 core-matter-server matter_server.server.client_handler[126] DEBUG [140550597330704] Handling command diagnostics
2023-10-11 08:07:11 core-matter-server matter_server.server.client_handler[126] WARNING [140550597329040] Disconnected: Received non-Text message.
Many thanks in advanced
