I tried to add a Meross plug which is using Wifi and to add it directly as Matter device to HA.
HA OS 11.1 with 2023.10.5 is running in proxmox.
The device provisioning via the HA works but then adding it to HA fails with the message it can’t find the device.
I can see the following in the logs of the matter server:
2023-10-30 16:04:30 core-matter-server chip.DIS[126] ERROR Timeout waiting for mDNS resolution.
2023-10-30 16:04:44 core-matter-server chip.DIS[126] ERROR OperationalSessionSetup[1:0000000000000004]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
2023-10-30 16:05:15 core-matter-server chip.DIS[126] ERROR Timeout waiting for mDNS resolution.
2023-10-30 16:05:29 core-matter-server chip.DIS[126] ERROR OperationalSessionSetup[1:0000000000000004]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
2023-10-30 16:06:00 core-matter-server chip.DIS[126] ERROR Timeout waiting for mDNS resolution.
2023-10-30 16:06:14 core-matter-server chip.DIS[126] ERROR OperationalSessionSetup[1:0000000000000004]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
2023-10-30 16:06:14 core-matter-server matter_server.server.client_handler[126] ERROR [140515388342672] Error handling message: CommandMessage(message_id='d70b81f3aef146c3adab9d9c1a5c8860', command='commission_on_network', args={'setup_pin_code': 56458867})
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 889, in _resolve_node
await self._call_sdk(
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 766, in _call_sdk
await self.server.loop.run_in_executor(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.11/site-packages/chip/ChipDeviceCtrl.py", line 491, in ResolveNode
self.GetConnectedDeviceSync(nodeid, allowPASE=False)
File "/usr/local/lib/python3.11/site-packages/chip/ChipDeviceCtrl.py", line 731, in GetConnectedDeviceSync
returnErr.raise_on_error()
File "/usr/local/lib/python3.11/site-packages/chip/native/__init__.py", line 67, in raise_on_error
raise self.to_exception()
chip.exceptions.ChipStackError: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 304, in interview_node
await self._resolve_node(node_id=node_id)
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 897, in _resolve_node
await self._resolve_node(node_id=node_id, retries=retries - 1)
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 896, in _resolve_node
raise NodeNotResolving(f"Unable to resolve Node {node_id}") from err
matter_server.common.errors.NodeNotResolving: Unable to resolve Node 4
File "/usr/local/lib/python3.11/site-packages/matter_server/server/client_handler.py", line 188, in _run_handler
result = await result
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 221, in commission_on_network
await self.interview_node(node_id)
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 314, in interview_node
raise NodeInterviewFailed(f"Failed to interview node {node_id}") from err
matter_server.common.errors.NodeInterviewFailed: Failed to interview node 4
So the issue seems to be mDNS as it can’t find the node.
What I don’t understand is that mDNS works in general in my network and I can even see the matter devices in a services browser. HA can also be found via the mDNS address.
Then I tried to add the same device to Google via a Nest hub. And that worked instantly. So maybe the mDNS resolution is only an issue with HA? The firewall in proxmox is disabled.
As a last step I wanted to share the device from Google home to HA but there I also got an error:
2023-10-30 16:44:01 core-matter-server chip.CTL[126] ERROR Commissioning discovery over BLE failed: src/platform/Linux/BLEManagerImpl.cpp:682: CHIP Error 0x00000003: Incorrect state
2023-10-30 16:44:01 core-matter-server chip.-[126] ERROR src/platform/Linux/BLEManagerImpl.cpp:682: CHIP Error 0x00000003: Incorrect state at src/controller/SetUpCodePairer.cpp:299
2023-10-30 16:44:01 core-matter-server chip.BLE[126] ERROR No adapter available for new connection establishment
2023-10-30 16:44:01 core-matter-server chip.CTL[126] ERROR Found unconnected device, removing
2023-10-30 16:44:04 core-matter-server chip.EM[126] ERROR OnMessageReceived failed, err = src/messaging/ExchangeMgr.cpp:304: CHIP Error 0x00000070: Unsolicited msg with originator bit clear
2023-10-30 16:44:06 core-matter-server chip.CTL[126] ERROR Failed to perform commissioning step 13
2023-10-30 16:44:06 core-matter-server matter_server.server.client_handler[126] ERROR [140515388342672] Error handling message: CommandMessage(message_id='67d17fe535df4b3c80da58177e2c5b8e', command='commission_with_code', args={'code': '32917048316'})
File "/usr/local/lib/python3.11/site-packages/matter_server/server/device_controller.py", line 171, in commission_with_code
raise NodeCommissionFailed(
matter_server.common.errors.NodeCommissionFailed: Commission with code failed for node 7
2023-10-30 16:44:06 core-matter-server chip.EM[126] ERROR Failed to send Solitary ack for MessageCounter:253363943 on exchange 52590i:src/messaging/ExchangeContext.cpp:144: CHIP Error 0x00000002: Connection aborted
That one is really odd as it should not provision via BLE? And if it does, it should use the one from the mobile phone and not from HA?
