Hi all,
I noticed recently that Google pushed an update to my Nest Thermostats (3rd gen/mirror) and they now have Matter support. My biggest frustration with these devices is that they rely on a cloud API; I haven’t had any issues, but I don’t love that I’m dependent on Google for this basic functionality, so seeing Matter support was exciting and I immediately decided to test it out.
I installed the Matter (Beta) addon and the associated integration which went smoothly. However, when I tried to add the thermostats via the Matter integration I’m getting constant errors although nothing shows in addon the logs.
A little information about my HA setup:
VM on XCP-ng pool imported using the VDI file
VM is configured with 2 NICs:
ENX0 - Connected to the IoT network where all the devices live. This interface has IPv6 enabled (auto) and IPv4 enabled (static with only IP address, no gateway, no DNS)
ENX1 - Connected to the ‘LAN’. This interface has IPv6 disabled and IPv4 enabled (auto) with gateway and DNS populated by DHCP.
Add-on: Matter Server
Matter WebSocket Server for Home Assistant Matter support.
Add-on version: 5.4.1
You are running the latest version of this add-on.
System: Home Assistant OS 12.1 (amd64 / qemux86-64)
Home Assistant Core: 2024.3.3
Home Assistant Supervisor: 2024.03.0
I don’t recall specifically why I configured the VM with 2 interfaces as detailed above, but I know there was a reason and I’m hesitant to change the NIC config and risk breaking things. (It may have been related to how I have my network laid out and where Apple TVs and a UniFi NVR needed to live).
Now one thing I’ve noticed that could be contributing to the problem is that when I check the logs for the Matter addon it’s trying to use ENX1 as the primary interface instead of ENX0 (where the devices live) but there I can’t find anywhere to change this. My thought is that it may be trying to establish a connection out of interface ENX1 which is then blocked from accessing the IoT network. I found the addon’s config file on the github page and it seems to indicate that the container should be using host networking, but if it is it doesn’t seem to be detecting or leveraging the ENX0 interface.
I understand that the Matter standard/protocol and the Matter implementation in HA are still in their infancy (hence the BETA branding on everything). Any settings or troubleshooting steps anyone can recommend? I’m happy to provide additional information or details about my configuration, but I don’t even know where to begin with this!
