I just wanted to see if anyone else has this issue, since installing the Matter integration I currently have 5606 Matter backups! I am not sure if this is the right area to post this but any advice on how to debug this would be great. I am going to remove the add-on for now but will want to use Matter at some point soon so would like to be able to use it with out KO my HDD in a few weeks
Its the integration, I have not installed any add-on for matter it was installed though the devices and services → add integration. I mention add-on as you can see the backup is called “add-on” didnt mean to cause confusion
I have one that was not removed in the purge, just had a look, seems like a backup JSON config file and a copy of the bin i guess “core_matter_server.tar.gz”
