Matter bindings: controlling TRV with external room temperature sensor
A developer from Eve recently mentioned in this reddit comment that the Eve Thermo Control device uses standard Matter bindings to control the Eve Thermo TRVs based on the external room temperature sensor:
“It’s a Matter feature. If Home Assistant supports these, you would just need to know which clusters to bind against and which access control entries to write out. If the Home Assistant team would want to add this, I could provide this information. :)”
Is there anyone here with the expertise who could find out how to use Matter bindings to connect a TRV with a room temperature sensor? This could be a huge improvement—not just for these devices, but for many others. With all the data available in a smart home, it’s inefficient for a TRV to rely only on its built-in sensor, which likely doesn’t reflect the actual room temperature.
Thanks!
+1
I just ordered me 7 of these Eve Thermo Control devices and would like to see this supported in Home Assistant.
I second this, it would be cool to control other devices in HA and assign temp sources to existing thermo
That would be awesome
I don’t have those devices, but I’ve just written a script to bind 2 Matter devices in HA. Successfully used to bind an Inovelli switch to a Nanoleaf bulb. Feel free to try it on your thermo devices.
Details here: Matter Bindings [script]
Any success controlling the temperature so far?
