Matter device can not be connected
Hi
I try to connect a matter/wifi powerswitch to my HA
Steps I do:
  • connect mobile phone (pixel 7a) to same network as the HA is connected to
  • reset the matter switch (button for 5-10s)
  • scan the QR code with android phone (Home assistant companion app is installed)
  • Phone asks to install device
  • select “other app - home assistant”
  • “searching for device”
  • “device is beeing configured”
  • device gets IP address and is pingable
    -" Network connection to “” is beeing tested"
    this is showing for about 5 min or so
  • “no connection to device possible”
  • :frowning:
Does anyone have an idea?
Thomas
Are you connected to the internet while you doing this? Matter devices can’t be commissioned offline (at least at the moment?) :thinking:
Matter relies on multicast DNS to discover commissionable devices, and typically if you have a separate vlan or subnet, these multicast packets don’t survive passing through a router to get to HA. Routers can often be configured to forward mdns, but each routers’ settings are different which is why separate vlans are currently discouraged.
I have deployed several Matter-over-WiFi devices to an isolated vlan with no internet access, so that’s likely not the issue, but my HA server has a second NIC on this vlan so it can receive the mdns packets.
Did you run a local DCL (Distributed Compliance Ledger) node to deploy offline matter devices? @Pierre84000 might be interested in this :wink:
My understanding is the Matter server downloads the DCL (potentially from Nabu Casa, since they are a member of the CSA), not the end device or the commissioning device. At least that is how my iPhone worked, maybe Android is different.
Hi there,
I’ve been through exactly the same hassle. Probably spent some 15 hours on it with no luck. Solution was to connect via Bluetooth instead.
Please check out this thread: Matter Pairing/Commissioning hints
Credit goes to @Pierre84000 for having pointed me to this and of course @agners who maintains the Matter add-on.
If you need further details, have a look at Matter/Thread: connecting new device gets stuck in "Checking network connection" - #9 by wmaker and read the last 4-5 postings at the end of the thread.
AFAIK if you use apple gear you auto magically make use of the vendor cloud - are your certain your apple phone was offline when commissioning? (maybe it had a mobile connection) :thinking:
Same for android, then it’s google cloud and no apple cloud :cloud:
FWIW, I just commissioned a Tasmota Matter device with my cell radio disabled, only private WiFi and bluetooth, no issues :exploding_head:. Again, my Matter server is dual-homed, so it can fetch the certs:
peter@felix:/opt/matter/data$ grep -i dcl matter-server.log
2024-09-30 13:42:48.828 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetching the latest PAA root certificates from DCL.
2024-09-30 13:42:50.688 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetched 63 PAA root certificates from DCL.
2024-09-30 13:42:51.811 (MainThread) INFO [matter_server.server.vendor_info] Fetching the latest vendor info from DCL.
2024-09-30 13:42:52.154 (MainThread) INFO [matter_server.server.vendor_info] Fetched 247 vendors from DCL.
Is this with a matter over wifi or matter over thread device you had issue commissioning?
