Over the last few days my Inovelli switches continue to show as unavailable. They become available briefly but then they become unavailable again. I’m running
Core 2025.1.1
Supervisor 2024.12.3
Operating System 14.1
Frontend 20250106.0
Is it possible that my 2.4ghz WIFI is interfering with my Thread Border Router? The Border Router runs on channel 14 and my 2.4ghz is running on channel 1.
Also when I ping the device I get IPV4 and IPV6 but another address that doesn’t ping
No, I have over 25 White switches are they are rock solid. Matter device unavailability usually (not always) points to a local network issue of some type.
Please make sure your router is not restricting access to known devices (MAC address filter). Took me days to identify why matter/thread network was unreliable, same as you described.
I must admit that this wasn’t the solution as devices still became unavailable after some time, unfortunately. I now have locked the WIFI channel to 11, which make all my 6 tado X devices show up fine since last 3 days. Keeping my fingers crossed…
Update: Setting the Wifi channel to 11 didn’t solve the issue, but adding a new bulb, which also acts as a Thread repeater, solved the issue for me finally! No disconnect experienced for the part two weeks now.
I should say you need to use something like Wifi Analyzer to make sure that you know which channel to use and set your 2.4ghz channel. For me 11 was magical.
I know this is old but I was having the same issues, I have a Google Nest Hub Max and another Hub the 2nd Gen acting as Thread Border Router, I power cycle the hub max to start with and the switch became available again.
Are you still having this issue? I see this with at least one of my switches at least once a week, and constantly having to power cycle the switch, or the border routers, dooesn’t seem like a viable long term solution
@seoMattH - Can you elaborate on your 2.4ghz channel solution?
