Matter Govee Fan state not updating
I’m pretty new to Home Assistant, but been adding things and today added my Govee fan via Matter, the only Matter device I have. I have a weird issue and just curious if this is known or maybe if someone has an opinion on whether the fault is in the Matter integration or the fan firmware.
Essentially, if I turn the fan on with the physical button, HA picks up the state just fine. if I turn it on via the toggle in Home Assistant, the fan turns on, but the state still remains off unless I make another change in the app like make the fan speed faster. When I turn the fan off with the toggle, the state updates with no issue. So…does this seem like a bug in the Govee fan firmware or something with the Matter integration? I’m guessing Govee doesn’t send an on state update or something, but I’m not sure.
Hard to tell which one is at fault. One possible way to find out is to goto your Matter Server AddOn and open up the Webpage and go to your Govee fan. Then the fun part comes trying to figure out what clusters the fan has and if there is one like “onoff” and whether its state is correct or not.
