I decided to switch out some lights to matter devices (Linkind). Paired up quickly and seemed to work fine while testing. But I ended up having a problem about 8 hours later.
So anytime after about 8 hours, the first response is very slow, i.e. I turn it on and it takes 6-12 seconds to turn on. HA send it out immediately. After that initial delay, then everything is sub-second response time. Let it sit for 8 hours and then same results. The light always has power as the light switch has a protector to keep power on.
Same issue for me as well with Linkind Matter lights. It’s been happening ever since I purchased and set up the lights last month. The delay is extremely irritating: up to a 10 second delay from the time HA entity state is changed to the time the bulb actually turns on, but only only after it’s been sitting for a while.
I can confirm this behavior as well using OREiN smart bulbs from Amazon. Subsequent requests are fast, it’s just that first request after a period of no activity that has a huge delay (several seconds).
Same problem here. Different light bulbs, but exact same behavior. I have 3 mujoy Matter bulbs that worked perfectly for months and then started responding really slowly to turn on calls. Adjusting brightness also is super slow now. Screen Recording
