Choose the right smart blind solution for Home Assistant: MTP1 / ZMP1 / MT25B / MT15B / ZM25Z
When building a smart home with Home Assistant (HA), one of the most common questions is:
Should I choose Matter or Zigbee?
Should I use a retrofit chain driver or a full roller motor system?
Zemismart offers both ecosystems and both installation types, giving users flexibility depending on their home setup, installation preference, and smart home platform strategy.
This guide helps you quickly choose the right option.
1. Two Installation Types: Retrofit Driver vs Roller Motor
Retrofit Chain Driver (MTP1 / ZMP1)
Retrofit motors are designed to upgrade your existing curtains without replacing the whole system.
MTP1 (Matter over Thread Retrofit Driver)
- Matter over Thread protocol
- Battery-powered built-in system
- Works with Home Assistant / Apple Home / Google Home
- Clips directly onto bead chain
- No need to replace curtain hardware
Best for: fast smart upgrade without renovation
ZMP1 (Zigbee Retrofit Driver)
- Zigbee mesh connection
- Works with Zigbee2MQTT / ZHA / Home Assistant
- Stable local automation control
- Ideal for existing Zigbee users
Best for: users already using Zigbee ecosystem
Key Advantage of Retrofit Drivers
- Very easy installation (minutes)
- No construction required
- Fully reversible (can remove anytime)
- Ideal for renters or quick upgrades
Limitation: visible design + lower load capacity compared to roller motors
2. Roller Motor System (Permanent Installation)
Roller motors replace the internal tube of the curtain system, providing a cleaner and more professional look.
ZM25Z (Zigbee Plug-in Roller Motor)
- Zigbee protocol
- Plug-in power (no charging required)
- Stable continuous operation
- Suitable for 38mm roller tubes
- High torque for large curtains
Best for: maximum stability + zero battery maintenance
MT25B (Matter over Thread + Battery + Solar Support)
Zemismart Matter over Thread Roller Shade Motor
- Built-in rechargeable battery
- Supports solar panel charging
- Designed for 38mm tubes
Best for: wireless premium smart home setup
Solar option makes it ideal for long-term low-maintenance installations
MT15B (Matter over Thread for Small Tubes)
- Supports 17 / 20 / 25 / 28mm tubes
- Built-in battery
- Designed for lightweight blinds
Best for: small windows or light roller shades
Currently no plug-in version available for MT15B
3. Matter vs Zigbee in Home Assistant
Zigbee (ZM25Z / ZMP1)
Zigbee is a mature smart home protocol widely used in Home Assistant setups.
- Very stable mesh network
- Large device ecosystem (lights, sensors, blinds)
- Excellent support in ZHA / Zigbee2MQTT
- Scales very well in large homes
Key point:
More Zigbee devices = stronger network mesh
Best for:
- Advanced Home Assistant users
- Large-scale smart homes
- Multi-device automation systems
Matter over Thread (MTP1 / MT25B / MT15B)
Matter over Thread is the next-generation smart home standard.
- IP-based architecture
- Native support for Apple / Google / Home Assistant
- Self-healing Thread mesh
- Low latency and fast response
Consideration:
- Requires Thread Border Router
- Ecosystem still growing
- Device capacity per network is generally lower than Zigbee
Best for:
- Apple Home users
- Cross-platform smart home setups
- Future-proof installations
4. Real Smart Home Selection Guide
Choose Retrofit Chain Driver if:
- You want fast installation
- You don’t want to replace curtains
- You are renting
MTP1 (Matter) / ZMP1 (Zigbee)
Choose Roller Motor if:
- You are building or renovating
- You want clean hidden installation
- You have large or heavy curtains
ZM25Z / MT25B / MT15B
Choose Zigbee if:
- You already use Zigbee in Home Assistant
- You want large-scale device networking
Choose Matter if:
- You want Apple Home / multi-platform compatibility
- You want a future-proof ecosystem
5. Key Summary
- Retrofit Driver = easiest smart upgrade (no replacement needed)
- Roller Motor = clean, permanent, premium installation
- Zigbee = stable, scalable, mature ecosystem
- Matter over Thread = modern, cross-platform future standard
