Anyone have experience connecting an existing light strip to network via Matter Over WiFi Led Strip Light Controller?
Specifically, I have a Tuya light strip and would like to start using matter, to remove all the other controllers I’m using, ie. Tuya, zigbee. Rather than replace all strips, wondering if connecting over of these controllers to the strips would work.
I just setup the Zemismart Matter-over-WiFi RGBCW controller with my year-old BTF-Lighting 24v strip. This controller should work with 4-wire (RGB), 5-wire (RGBW), and 6-wire (RGBCW) non-addressable 12v or 24v strips, though be advised the integration doesn’t let you specify which wires are connected and just assumes they all are. If your old strips are 5v, or use addressable ICs (WS28xx, etc), then this controller won’t work for you, as it’s just a straight 5-channel dimmer module.
