Matter power monitoring plug: on/off controls only?
I installed the Matter integration to test a Meross MSS315 smart plug, listed as having energy monitor feature, as an alternative to ZWave Aeotec smart plugs I already use.
Once installed, I only see the on/off command in the device and no other entities.
Could it be an issue (or choice) in the device to not expose usage monitoring data or is it because of Matter → only handling the basic stuff?
Looking for an answer, I found this post which does suggest Matter it is not there yet.
Can you educate me on the Matter objectives in the scope of Home Assistant?
I suppose I will continue to rely on ZWave for real sensors and devices.
Matter does not yet support power monitoring, it was supposed to have arrived this autumn, but it did not. I suspect that’s the reason Belkin stepped away from matter for the time being. It will hopefully arrive in February / March with the next matter update.
Any info here? I have the same… installed a matter plug but have only on/off button
Still the same, Matter 1.2 does not support energy monitoring.
Hopefully CSA will release Matter 1.3 soon, and hopefully they will add support for energy monitoring in the specs.
I have bought some cheap Matter sockets from Aliexpress. They announced power measurement, but I also get only on/off switch in HA. They should be Matter v1 devices.
Now the question is, whether they do not support power measurement at all it only works with some proprietary hub.
If I understand it correctly, power measurement is not yet standardized by Matter, so it makes no sense to buy Matter devices with power measurement yet? Or is it only Matter Server, that does not support power measurement yet?
The current Matter specification (1.2) does not support power reporting. It is promised for version 1.3
Looking promising:
Am I correct that the product company (i.e. Aqara smart plugs in my case) needs to first implement power monitoring for their smart plugs before the Aqara matter implementation would be able to report it, even if the integration support the latest 1.3 spec?
yes, that is correct.
I bought a Matter smart plug from Moes, which looks like the same generic Tuya smart plug that everybody rebrands.
I have the UK version.
Out of the box, there were no firmware updates. I shared the device over matter from the Moes app (reskinned Tuya smart life app) instead of adding directly to HA for firmware update purposes.
Power monitoring was detected and working out of the box.
Can you show some screenshots of how you shared it from the Moes app?
I recently purchased some Meross MSS315 plugs. I had the same result as the OP from 1 year ago. It’s interesting that the HA integrations for Tuya, and Meross, also include the power statistics for power consumption-monitoring capable smartplugs, but the Matter integration does not for these plugs.
I’m hoping FW updates for the plugs will add that ability, but I’m not holding my breath.
EDIT: Meross updated their US FW maybe a day or so ago to 9.5.33 and now this plug integrates with Matter showing the power stats. Great!
This is good to know. I have some TAPI P110M Outlets. Adding them through the TP-Link integration I can see the the energy monitoring details. Adding them through Matter I do not.
For the Tapo outlets it’s probably the best to follow the thread in the TP-Link forum.
It seems like there is a beta firmware that adds Matter 1.3 support, including energy monitoring. The plugs are already Matter 1.3 certified but the firmware is not released yet.
Does anybody know about NOUS A8M matter smart plugs? Do these need an update, too?
