Matter Server and IPTV (Movistar+). Incompatible?
Hi all:
I’ve been experiencing problems with my IPTV (movistar+) service. Image keep freezing or pixelating all the time. At first sight it seems to be a Service problem, so I contacted the operator and as a result of this incident they changed the Router and the Deco. Unfortunately this doesn’t resolve the problem. At this point I started to make troubleshooting in the LAN. I have a HA Green connected via Ethernet to the LAN and the Zigbee integration with 90% devices being ZigBee ones. I tried going backwards in my configuration looking for a point where IPTV service had been worked properly and … It started to work again after deinstalling Matter Server. I understand that there are a lot of different factors that can contribute to make a LAN unstable but coult it be possible that matter server can intruduce some broadcast traffic in the LAN to the point of generate a LAN traffic congestion? Any suggestions or explanations are wellcome. Thanks in advance community!
