I had matter working fine until I had to do a full backup restore. Now after the restore, the matter server will not start. I’ve uninstalled it, rebooted, reinstalled it, rebooted, and it still didn’t start, even with manual start. This is in my supervisor log:
23-10-14 14:32:13 INFO (MainThread) [supervisor.store] Loading add-ons from store: 74 all - 0 new - 0 remove
23-10-14 14:32:24 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping addon_core_matter_server application
23-10-14 14:32:29 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_core_matter_server application
23-10-14 14:32:30 INFO (SyncWorker_2) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-matter-server with latest
23-10-14 14:32:30 INFO (SyncWorker_2) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-matter-server with 4.9.0
23-10-14 14:32:31 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/core_matter_server
23-10-14 14:32:31 INFO (MainThread) [supervisor.discovery] Delete discovery to Home Assistant matter from core_matter_server
23-10-14 14:32:32 INFO (MainThread) [supervisor.addons] Add-on 'core_matter_server' successfully removed
23-10-14 14:32:32 INFO (MainThread) [supervisor.discovery] Discovery d1cafc8cd3c34854a56946cc7bb2c2da message send
23-10-14 14:32:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
23-10-14 14:32:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-10-14 14:32:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/koush/scrypted repository
23-10-14 14:32:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-10-14 14:32:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-10-14 14:32:40 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc...
23-10-14 14:32:41 WARNING (SyncWorker_3) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc...
23-10-14 14:32:41 INFO (MainThread) [supervisor.store] Loading add-ons from store: 74 all - 0 new - 0 remove
23-10-14 14:33:04 INFO (SyncWorker_5) [supervisor.docker.manager] Restarting homeassistant
23-10-14 14:33:27 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
23-10-14 14:33:27 WARNING (MainThread) [supervisor.misc.tasks] Watchdog miss API response from Home Assistant
23-10-14 14:33:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-10-14 14:33:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-10-14 14:33:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
23-10-14 14:33:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-10-14 14:33:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/koush/scrypted repository
23-10-14 14:33:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-10-14 14:33:38 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-10-14 14:33:38 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-10-14 14:33:40 WARNING (SyncWorker_6) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc...
23-10-14 14:33:41 WARNING (SyncWorker_6) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc...
23-10-14 14:33:41 INFO (MainThread) [supervisor.store] Loading add-ons from store: 74 all - 0 new - 0 remove
23-10-14 14:34:43 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
23-10-14 14:37:59 INFO (MainThread) [supervisor.host.info] Updating local host information
23-10-14 14:38:00 INFO (MainThread) [supervisor.host.services] Updating service information
23-10-14 14:38:00 INFO (MainThread) [supervisor.host.network] Updating local network information
23-10-14 14:38:01 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-10-14 14:38:01 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-10-14 14:44:01 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/core_matter_server
23-10-14 14:44:01 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-matter-server with tag 4.9.0.
23-10-14 14:44:42 INFO (MainThread) [supervisor.addons] Add-on 'core_matter_server' successfully installed
23-10-14 14:48:21 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-matter-server with version 4.9.0
23-10-14 14:48:25 INFO (MainThread) [supervisor.discovery] Sending discovery to Home Assistant matter from core_matter_server
23-10-14 14:48:25 INFO (MainThread) [supervisor.discovery] Discovery 878d70248b02493e9ce7abf5d33787db message send
23-10-14 14:48:57 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
23-10-14 14:48:57 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-10-14 14:48:57 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/koush/scrypted repository
23-10-14 14:48:57 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-10-14 14:48:57 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-10-14 14:48:57 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-10-14 14:48:59 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc...
23-10-14 14:49:00 WARNING (SyncWorker_4) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc...
23-10-14 14:49:00 INFO (MainThread) [supervisor.store] Loading add-ons from store: 74 all - 0 new - 0 remove
23-10-14 14:50:21 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Matter Server to start, took more then 120 seconds
(For some reason Ring wants to start even though I don’t have any Ring devices and no integrations or servers, but that’s a separate issue, I hope.) The Matter integration obviously doesn’t work because the server won’t start. Any ideas?
