Matter-server with docker not working correctly
I’m running the matter-server using docker (portainer) with the following code:
version: "3.9"
services:
  matter-server:
    container_name: "matter-server"
    image: "ghcr.io/home-assistant-libs/python-matter-server:stable"
    network_mode: "host"
    restart: "unless-stopped"
    security_opt:
      - "apparmor:unconfined"
    volumes:
      - /run/dbus:/run/dbus:ro
      - nfs-matter:/data
volumes:
  nfs-matter:
    external: true
The log of the matter container shows me the following errors:
2023-11-18 00:41:46 mini-server chip.DIS[1] ERROR DNSSD packet parsing failed (for SRV records)
2023-11-18 00:41:46 mini-server chip.DIS[1] ERROR DNSSD packet parsing failed (for non-srv records)
I was able to get connected to my aqara hub, but I cannot connect it to my switchbot hub. After I enter the pin it get stuck on " Add Matter device":
Similarly, if I try to add a Nanoleaf matter bulb that I had configured on google home:
How can I fix this?
I made progress narrowing the problem, but I still need help to solve it. If I run the same docker container on my Synology everything works fine. So I’m guessing this has to do with my Ubuntu server. Alas, no clue what it could be nor how to solve it. My Ubuntu server is only a few days old, so other than installing a few containers with portainer I did not change anything. Any ideas for how to solve this? I would really like to have all my containers running there instead of having all but the matter server.
Matter require an enabled and working IPv6 network.
DNSSD is DNS discovery for IPv6.
Thanks. This is what I get if I run mdns-scan on my ubuntu server:
ignacio@mini-server:~$        mdns-scan
+ Nest 8298._hap._tcp.local
+ Homebridge 2FB2 2A59._hap._tcp.local
+ Govee C435._hap._tcp.local
+ SHIELD-Android-TV-af1054f10c021c17fb736d7393e96c98._googlecast._tcp.local
+ af1054f1-0c02-1c17-fb73-6d7393e96c98._googlezone._tcp.local
+ synology._http._tcp.local
+ Google-Home-Mini-0e77d706d85241cb645a38b6c72392be._googlecast._tcp.local
+ 0e77d706-d852-41cb-645a-38b6c72392be._googlezone._tcp.local
+ synology._webdavs._tcp.local
+ iTunes_Ctrl_001132554C4F6011._dacp._tcp.local
+ google-cast-group-809b15b4b30f4d70a0736ffaa84ba093._googlecast._tcp.local
+ Google-Nest-Mini-8efa0ce7aef0999460dd6b47c624e6ef._googlecast._tcp.local
+ google-nest-hub-max-b45440fbd0cadb9cfb8faa526b0c1b45._googlecast._tcp.local
+ google-cast-group-ba24b9950f6b4af1befeecdebd25652b._googlecast._tcp.local
+ 3251895042._zwave-js-server._tcp.local
+ 8efa0ce7-aef0-9994-60dd-6b47c624e6ef._googlezone._tcp.local
+ google-cast-group-ea432b1bfea0416491ab32d56718a82b._googlecast._tcp.local
+ b45440fb-d0ca-db9c-fb8f-aa526b0c1b45._googlezone._tcp.local
+ Google-Home-Mini-5d626d24c333bb989093e453b077a3e2._googlecast._tcp.local
+ 5d626d24-c333-bb98-9093-e453b077a3e2._googlezone._tcp.local
+ Casa._home-assistant._tcp.local
+ google-nest-hub-f1474465b40e4b3813b3d0c8b26c86de._googlecast._tcp.local
+ Big bedroom tv._androidtvremote2._tcp.local
+ Home Assistant Silicon Labs Multiprotocol #2E47._meshcop._udp.local
+ adb-0324616160712._adb._tcp.local
+ SHIELD._nv_shield_remote._tcp.local
+ SHIELD._androidtvremote2._tcp.local
+ 38c3d37d-9113-95bc-9984-5d44e95fe7dc._googlezone._tcp.local
+ SHIELD-Android-TV-6724a7342d620427e670f804145783a5._googlecast._tcp.local
+ Google-Home-Mini-eacf38f74adb8ac0d6ec2b105cf5dc80._googlecast._tcp.local
+ eacf38f7-4adb-8ac0-d6ec-2b105cf5dc80._googlezone._tcp.local
+ 41F1E2AE47766CD7-0000000092FE5905._matter._tcp.local
+ f1474465-b40e-4b38-13b3-d0c8b26c86de._googlezone._tcp.local
+ fb1e64a59d514c33883bcb5be095b767._mass._tcp.local
+ google-nest-hub-49cb4aa260f8b0cd05154c7d7ac6013f._googlecast._tcp.local
+ 49cb4aa2-60f8-b0cd-0515-4c7d7ac6013f._googlezone._tcp.local
I’m not sure if this indicates that I have a working IPv6 network or not. If not, could you point me in the right direction?
Do you have an IPv6 address and do you have an IPv6 route?
System information as of Sat Nov 18 09:52:01 PM UTC 2023
  System load:                      0.29345703125
  Usage of /:                       45.8% of 97.87GB
  Memory usage:                     21%
  Swap usage:                       0%
  Processes:                        702
  Users logged in:                  1
  IPv4 address for br-238f27e86414: 172.18.0.1
  IPv4 address for br-29944a68b720: 172.20.0.1
  IPv4 address for br-44b5af0d95d3: 172.19.0.1
  IPv4 address for br-6436b81957c5: 192.168.112.1
  IPv4 address for br-69e2bfff8575: 192.168.16.1
  IPv4 address for br-6d0e90782bb4: 172.26.0.1
  IPv4 address for br-79780bb1414a: 192.168.96.1
  IPv4 address for br-928f8e320bbb: 172.31.0.1
  IPv4 address for br-988da5e3d8e9: 192.168.48.1
  IPv4 address for br-a15da67a81f6: 172.22.0.1
  IPv4 address for br-abca2820dcf9: 172.23.0.1
  IPv4 address for br-c051d0e2cfbb: 172.27.0.1
  IPv4 address for br-c59156a0d0ba: 172.29.0.1
  IPv4 address for br-c8c7d7669f5e: 192.168.224.1
  IPv4 address for br-ce35aa469fe4: 172.28.0.1
  IPv4 address for br-cfb31f42229c: 192.168.160.1
  IPv4 address for br-ddaab3cc9868: 192.168.32.1
  IPv4 address for br-e2f8ae621efe: 192.168.64.1
  IPv4 address for br-ee1c7a9193a2: 172.24.0.1
  IPv4 address for docker0:         172.17.0.1
  IPv4 address for eno1:            192.168.86.124
  IPv6 address for eno1:            fd2c:c63b:6f3:6a0a:a3bf:5969:a284:f209
  IPv6 address for eno1:            fd2c:c63b:6f3:6a0a:5a47:caff:fe70:b187
  IPv4 address for otbr0:           172.21.0.1
  IPv6 address for otbr0:           2001:db8:1::1
  IPv6 address for wpan0:           fd15:3ceb:c38c::ff:fe00:fc11
  IPv6 address for wpan0:           fd34:c3f7:9501:1:2019:999a:247d:3e51
  IPv6 address for wpan0:           fd15:3ceb:c38c::ff:fe00:fc10
  IPv6 address for wpan0:           fd15:3ceb:c38c::ff:fe00:fc38
  IPv6 address for wpan0:           fd15:3ceb:c38c::ff:fe00:fc00
  IPv6 address for wpan0:           fd15:3ceb:c38c::ff:fe00:e400
  IPv6 address for wpan0:           fd15:3ceb:c38c:0:a30b:a8d7:98b1:3e66
and
ignacio@mini-server:~$ /sbin/route -A inet6
Kernel IPv6 routing table
Destination                    Next Hop                   Flag Met Ref Use If
ip6-localhost/128              [::]                       U    256 2     0 lo
2001:db8:1::/64                [::]                       U    256 1     0 otbr0
fd15:3ceb:c38c::/64            [::]                       U    256 1     0 wpan0
fd2c:c63b:6f3:6a0a::/64        [::]                       UAe  256 20     0 eno1
fd34:c3f7:9501:1::/64          [::]                       U    256 1     0 wpan0
fe80::/64                      [::]                       U    256 1     0 otbr0
fe80::/64                      [::]                       U    256 17     0 eno1
fe80::/64                      [::]                       U    256 1     0 veth84a5162
fe80::/64                      [::]                       U    256 1     0 br-c59156a0d0ba
fe80::/64                      [::]                       U    256 1     0 veth01a5560
fe80::/64                      [::]                       U    256 1     0 docker0
fe80::/64                      [::]                       U    256 1     0 vethd44570a
fe80::/64                      [::]                       U    256 1     0 br-abca2820dcf9
fe80::/64                      [::]                       U    256 1     0 veth1a37df8
fe80::/64                      [::]                       U    256 1     0 br-ce35aa469fe4
fe80::/64                      [::]                       U    256 1     0 veth1dd69b2
fe80::/64                      [::]                       U    256 1     0 br-ddaab3cc9868
fe80::/64                      [::]                       U    256 1     0 veth5ab994c
fe80::/64                      [::]                       U    256 1     0 br-6436b81957c5
fe80::/64                      [::]                       U    256 1     0 veth9717f49
fe80::/64                      [::]                       U    256 1     0 br-a15da67a81f6
fe80::/64                      [::]                       U    256 1     0 veth9896c27
fe80::/64                      [::]                       U    256 1     0 br-79780bb1414a
fe80::/64                      [::]                       U    256 1     0 veth6c7790d
fe80::/64                      [::]                       U    256 1     0 br-928f8e320bbb
fe80::/64                      [::]                       U    256 1     0 veth201c488
fe80::/64                      [::]                       U    256 1     0 br-69e2bfff8575
fe80::/64                      [::]                       U    256 1     0 veth734fc47
fe80::/64                      [::]                       U    256 1     0 br-c051d0e2cfbb
fe80::/64                      [::]                       U    256 1     0 veth4089d86
fe80::/64                      [::]                       U    256 1     0 br-6d0e90782bb4
fe80::/64                      [::]                       U    256 1     0 veth2671305
fe80::/64                      [::]                       U    256 1     0 br-ee1c7a9193a2
fe80::/64                      [::]                       U    256 1     0 veth8dd888e
fe80::/64                      [::]                       U    256 1     0 br-238f27e86414
fe80::/64                      [::]                       U    256 1     0 veth20980aa
fe80::/64                      [::]                       U    256 1     0 veth73713cc
fe80::/64                      [::]                       U    256 1     0 br-988da5e3d8e9
fe80::/64                      [::]                       U    256 1     0 vethf8b7998
fe80::/64                      [::]                       U    256 1     0 veth5871293
fe80::/64                      [::]                       U    256 1     0 veth74c834a
fe80::/64                      [::]                       U    256 1     0 br-e2f8ae621efe
fe80::/64                      [::]                       U    256 1     0 vetha55b92f
fe80::/64                      [::]                       U    256 1     0 veth2664bb4
fe80::/64                      [::]                       U    256 1     0 veth5454fb8
fe80::/64                      [::]                       U    256 1     0 veth18afc70
fe80::/64                      [::]                       U    256 1     0 veth156b94b
fe80::/64                      [::]                       U    256 1     0 veth953f49d
fe80::/64                      [::]                       U    256 1     0 veth0a9475a
fe80::/64                      [::]                       U    256 1     0 vethfb8b863
fe80::/64                      [::]                       U    256 1     0 veth22126d6
fe80::/64                      [::]                       U    256 1     0 wpan0
fe80::/64                      [::]                       U    256 1     0 veth5c7251e
fe80::/64                      [::]                       U    256 1     0 veth1c5d4f1
fe80::/64                      [::]                       U    256 1     0 veth841fdec
fe80::/64                      [::]                       U    256 1     0 br-29944a68b720
fe80::/64                      [::]                       U    256 1     0 br-cfb31f42229c
fe80::/64                      [::]                       U    256 1     0 veth3aa9bf9
fe80::/64                      [::]                       U    256 1     0 veth799ee39
[::]/0                         [::]                       !n   -1  1     0 lo
ip6-localhost/128              [::]                       Un   0   18     0 lo
fd15:3ceb:c38c::/128           [::]                       Un   0   5     0 wpan0
fd15:3ceb:c38c::ff:fe00:e400/128 [::]                       Un   0   3     0 wpan0
fd15:3ceb:c38c::ff:fe00:fc00/128 [::]                       Un   0   4     0 wpan0
fd15:3ceb:c38c::ff:fe00:fc10/128 [::]                       Un   0   3     0 wpan0
fd15:3ceb:c38c::ff:fe00:fc11/128 [::]                       Un   0   2     0 wpan0
fd15:3ceb:c38c::ff:fe00:fc38/128 [::]                       Un   0   2     0 wpan0
fd15:3ceb:c38c:0:a30b:a8d7:98b1:3e66/128 [::]                       Un   0   2     0 wpan0
mini-server/128                [::]                       Un   0   6     0 eno1
mini-server/128                [::]                       Un   0   15     0 eno1
fd34:c3f7:9501:1::/128         [::]                       Un   0   3     0 wpan0
mini-server/128                [::]                       Un   0   3     0 wpan0
fe80::/128                     [::]                       Un   0   3     0 br-c59156a0d0ba
fe80::/128                     [::]                       Un   0   3     0 br-ddaab3cc9868
fe80::/128                     [::]                       Un   0   3     0 vethd44570a
fe80::/128                     [::]                       Un   0   3     0 veth1a37df8
fe80::/128                     [::]                       Un   0   3     0 veth20980aa
fe80::/128                     [::]                       Un   0   3     0 br-238f27e86414
fe80::/128                     [::]                       Un   0   3     0 veth6c7790d
fe80::/128                     [::]                       Un   0   3     0 br-988da5e3d8e9
fe80::/128                     [::]                       Un   0   3     0 br-ee1c7a9193a2
fe80::/128                     [::]                       Un   0   3     0 veth1dd69b2
fe80::/128                     [::]                       Un   0   3     0 br-6436b81957c5
fe80::/128                     [::]                       Un   0   3     0 veth201c488
fe80::/128                     [::]                       Un   0   3     0 veth5871293
fe80::/128                     [::]                       Un   0   3     0 vetha55b92f
fe80::/128                     [::]                       Un   0   3     0 br-abca2820dcf9
fe80::/128                     [::]                       Un   0   3     0 veth734fc47
fe80::/128                     [::]                       Un   0   3     0 br-e2f8ae621efe
fe80::/128                     [::]                       Un   0   3     0 veth2671305
fe80::/128                     [::]                       Un   0   3     0 veth01a5560
fe80::/128                     [::]                       Un   0   3     0 veth8dd888e
fe80::/128                     [::]                       Un   0   3     0 br-ce35aa469fe4
fe80::/128                     [::]                       Un   0   3     0 veth84a5162
fe80::/128                     [::]                       Un   0   3     0 veth5ab994c
fe80::/128                     [::]                       Un   0   3     0 veth73713cc
fe80::/128                     [::]                       Un   0   3     0 br-79780bb1414a
fe80::/128                     [::]                       Un   0   3     0 br-69e2bfff8575
fe80::/128                     [::]                       Un   0   3     0 veth4089d86
fe80::/128                     [::]                       Un   0   3     0 veth2664bb4
fe80::/128                     [::]                       Un   0   3     0 docker0
fe80::/128                     [::]                       Un   0   3     0 vethf8b7998
fe80::/128                     [::]                       Un   0   3     0 veth9896c27
fe80::/128                     [::]                       Un   0   3     0 br-6d0e90782bb4
fe80::/128                     [::]                       Un   0   3     0 br-928f8e320bbb
fe80::/128                     [::]                       Un   0   3     0 br-a15da67a81f6
fe80::/128                     [::]                       Un   0   3     0 br-c051d0e2cfbb
fe80::/128                     [::]                       Un   0   3     0 veth9717f49
fe80::/128                     [::]                       Un   0   3     0 veth74c834a
fe80::/128                     [::]                       Un   0   3     0 veth5454fb8
fe80::/128                     [::]                       Un   0   3     0 veth18afc70
fe80::/128                     [::]                       Un   0   3     0 veth953f49d
fe80::/128                     [::]                       Un   0   3     0 veth156b94b
fe80::/128                     [::]                       Un   0   3     0 veth0a9475a
fe80::/128                     [::]                       Un   0   3     0 wpan0
fe80::/128                     [::]                       Un   0   3     0 vethfb8b863
fe80::/128                     [::]                       Un   0   3     0 veth22126d6
fe80::/128                     [::]                       Un   0   3     0 veth5c7251e
fe80::/128                     [::]                       Un   0   3     0 veth1c5d4f1
fe80::/128                     [::]                       Un   0   3     0 br-29944a68b720
fe80::/128                     [::]                       Un   0   3     0 veth841fdec
fe80::/128                     [::]                       Un   0   3     0 br-cfb31f42229c
fe80::/128                     [::]                       Un   0   3     0 veth3aa9bf9
fe80::/128                     [::]                       Un   0   3     0 veth799ee39
mini-server/128                [::]                       Un   0   3     0 br-6436b81957c5
mini-server/128                [::]                       Un   0   2     0 br-6d0e90782bb4
mini-server/128                [::]                       Un   0   12     0 br-c59156a0d0ba
mini-server/128                [::]                       Un   0   2     0 br-c051d0e2cfbb
mini-server/128                [::]                       Un   0   2     0 docker0
mini-server/128                [::]                       Un   0   2     0 br-69e2bfff8575
mini-server/128                [::]                       Un   0   3     0 br-abca2820dcf9
mini-server/128                [::]                       Un   0   3     0 br-988da5e3d8e9
mini-server/128                [::]                       Un   0   3     0 br-928f8e320bbb
mini-server/128                [::]                       Un   0   2     0 br-a15da67a81f6
mini-server/128                [::]                       Un   0   2     0 br-e2f8ae621efe
mini-server/128                [::]                       Un   0   5     0 br-238f27e86414
mini-server/128                [::]                       Un   0   4     0 br-ddaab3cc9868
mini-server/128                [::]                       Un   0   2     0 br-cfb31f42229c
mini-server/128                [::]                       Un   0   2     0 br-29944a68b720
mini-server/128                [::]                       Un   0   2     0 br-79780bb1414a
mini-server/128                [::]                       Un   0   5     0 br-ee1c7a9193a2
mini-server/128                [::]                       Un   0   2     0 br-ce35aa469fe4
mini-server/128                [::]                       Un   0   2     0 veth734fc47
mini-server/128                [::]                       Un   0   2     0 veth201c488
mini-server/128                [::]                       Un   0   2     0 veth156b94b
mini-server/128                [::]                       Un   0   2     0 veth73713cc
mini-server/128                [::]                       Un   0   4     0 veth01a5560
mini-server/128                [::]                       Un   0   2     0 vethf8b7998
mini-server/128                [::]                       Un   0   2     0 vetha55b92f
mini-server/128                [::]                       Un   0   5     0 vethd44570a
mini-server/128                [::]                       Un   0   2     0 veth9717f49
mini-server/128                [::]                       Un   0   3     0 veth2671305
mini-server/128                [::]                       Un   0   2     0 veth9896c27
mini-server/128                [::]                       Un   0   3     0 veth22126d6
mini-server/128                [::]                       Un   0   12     0 eno1
mini-server/128                [::]                       Un   0   5     0 veth4089d86
mini-server/128                [::]                       Un   0   2     0 veth841fdec
mini-server/128                [::]                       Un   0   2     0 veth18afc70
mini-server/128                [::]                       Un   0   2     0 vethfb8b863
mini-server/128                [::]                       Un   0   2     0 wpan0
mini-server/128                [::]                       Un   0   2     0 veth5ab994c
mini-server/128                [::]                       Un   0   6     0 veth1dd69b2
mini-server/128                [::]                       Un   0   3     0 veth8dd888e
mini-server/128                [::]                       Un   0   2     0 veth84a5162
mini-server/128                [::]                       Un   0   3     0 veth2664bb4
mini-server/128                [::]                       Un   0   2     0 veth5c7251e
mini-server/128                [::]                       Un   0   5     0 veth1a37df8
mini-server/128                [::]                       Un   0   2     0 veth0a9475a
mini-server/128                [::]                       Un   0   2     0 veth5454fb8
mini-server/128                [::]                       Un   0   4     0 veth6c7790d
mini-server/128                [::]                       Un   0   2     0 veth74c834a
mini-server/128                [::]                       Un   0   4     0 veth5871293
mini-server/128                [::]                       Un   0   2     0 veth3aa9bf9
mini-server/128                [::]                       Un   0   5     0 veth20980aa
mini-server/128                [::]                       Un   0   2     0 veth953f49d
mini-server/128                [::]                       Un   0   2     0 veth799ee39
mini-server/128                [::]                       Un   0   3     0 veth1c5d4f1
ip6-mcastprefix/8              [::]                       U    256 18     0 eno1
ip6-mcastprefix/8              [::]                       U    256 17     0 veth84a5162
ip6-mcastprefix/8              [::]                       U    256 17     0 br-c59156a0d0ba
ip6-mcastprefix/8              [::]                       U    256 17     0 veth01a5560
ip6-mcastprefix/8              [::]                       U    256 17     0 docker0
ip6-mcastprefix/8              [::]                       U    256 17     0 vethd44570a
ip6-mcastprefix/8              [::]                       U    256 17     0 br-abca2820dcf9
ip6-mcastprefix/8              [::]                       U    256 17     0 veth1a37df8
ip6-mcastprefix/8              [::]                       U    256 17     0 br-ce35aa469fe4
ip6-mcastprefix/8              [::]                       U    256 17     0 veth1dd69b2
ip6-mcastprefix/8              [::]                       U    256 17     0 br-ddaab3cc9868
ip6-mcastprefix/8              [::]                       U    256 17     0 veth5ab994c
ip6-mcastprefix/8              [::]                       U    256 17     0 br-6436b81957c5
ip6-mcastprefix/8              [::]                       U    256 17     0 veth9717f49
ip6-mcastprefix/8              [::]                       U    256 17     0 br-a15da67a81f6
ip6-mcastprefix/8              [::]                       U    256 17     0 veth9896c27
ip6-mcastprefix/8              [::]                       U    256 17     0 br-79780bb1414a
ip6-mcastprefix/8              [::]                       U    256 17     0 veth6c7790d
ip6-mcastprefix/8              [::]                       U    256 17     0 br-928f8e320bbb
ip6-mcastprefix/8              [::]                       U    256 17     0 veth201c488
ip6-mcastprefix/8              [::]                       U    256 17     0 br-69e2bfff8575
ip6-mcastprefix/8              [::]                       U    256 17     0 veth734fc47
ip6-mcastprefix/8              [::]                       U    256 17     0 br-c051d0e2cfbb
ip6-mcastprefix/8              [::]                       U    256 17     0 veth4089d86
ip6-mcastprefix/8              [::]                       U    256 17     0 br-6d0e90782bb4
ip6-mcastprefix/8              [::]                       U    256 17     0 veth2671305
ip6-mcastprefix/8              [::]                       U    256 17     0 br-ee1c7a9193a2
ip6-mcastprefix/8              [::]                       U    256 17     0 veth8dd888e
ip6-mcastprefix/8              [::]                       U    256 17     0 br-238f27e86414
ip6-mcastprefix/8              [::]                       U    256 17     0 veth20980aa
ip6-mcastprefix/8              [::]                       U    256 17     0 veth73713cc
ip6-mcastprefix/8              [::]                       U    256 17     0 br-988da5e3d8e9
ip6-mcastprefix/8              [::]                       U    256 17     0 vethf8b7998
ip6-mcastprefix/8              [::]                       U    256 17     0 veth5871293
ip6-mcastprefix/8              [::]                       U    256 17     0 veth74c834a
ip6-mcastprefix/8              [::]                       U    256 17     0 br-e2f8ae621efe
ip6-mcastprefix/8              [::]                       U    256 17     0 vetha55b92f
ip6-mcastprefix/8              [::]                       U    256 17     0 veth2664bb4
ip6-mcastprefix/8              [::]                       U    256 17     0 veth5454fb8
ip6-mcastprefix/8              [::]                       U    256 17     0 veth18afc70
ip6-mcastprefix/8              [::]                       U    256 17     0 veth156b94b
ip6-mcastprefix/8              [::]                       U    256 17     0 veth953f49d
ip6-mcastprefix/8              [::]                       U    256 17     0 veth0a9475a
ip6-mcastprefix/8              [::]                       U    256 17     0 vethfb8b863
ip6-mcastprefix/8              [::]                       U    256 1     0 veth45e9799
ip6-mcastprefix/8              [::]                       U    256 17     0 veth22126d6
ip6-mcastprefix/8              [::]                       U    256 1     0 wpan0
ip6-mcastprefix/8              [::]                       U    256 17     0 veth5c7251e
ip6-mcastprefix/8              [::]                       U    256 17     0 veth1c5d4f1
ip6-mcastprefix/8              [::]                       U    256 17     0 veth841fdec
ip6-mcastprefix/8              [::]                       U    256 17     0 br-29944a68b720
ip6-mcastprefix/8              [::]                       U    256 17     0 br-cfb31f42229c
ip6-mcastprefix/8              [::]                       U    256 17     0 veth3aa9bf9
ip6-mcastprefix/8              [::]                       U    256 17     0 veth799ee39
I’m not sure if that is what you were asking (sorry, this is just a hobby, so I’m not really know all the lingo)
It looks like IPv6 is set up and working.
What does the addon logs say when you restart it.
This is my log.
2023-11-19 00:09:06 mini-server chip.DIS[1] ERROR DNSSD packet parsing failed (for SRV records)
2023-11-19 00:09:06 mini-server chip.DIS[1] ERROR DNSSD packet parsing failed (for non-srv records)
2023-11-19 00:09:09 mini-server chip.DIS[1] ERROR DNSSD packet parsing failed (for SRV records)
2023-11-19 00:09:09 mini-server chip.DIS[1] ERROR DNSSD packet parsing failed (for non-srv records)
im having the same issue. would love some guidance
Try to do a
ha resolution info
Sorry, where do I run that? I’m using docker for everything. I tried running it inside the home assistant docker container and the matter container. Both said that the command ha doesn’t exist
The command should be in the HA container.
It is at least by me with the Advanced SSH and web terminal addon.
Apparently not: Ha: command not found - #13 by francisp
The command ‘ha’ is in the hassio_cli container
Could you point me to the right docker compose to install that?
No idea. It is one of the 6 or so containers that gets installed when you run the supervisor .deb
How could you enable ipv6 for host network in docker (in Synology). Thank you
has anyone found a solution to this issue.
I did a fresh installation of HAOS on KVM and have the same error on the matter server. I cannot connect any thread device. Always: pairing failed
Did you find a solution for this?
