Matter VLANs and VMs - my setup
In Thread HA and VLANs - will this work? i’ve reported issues but got it to work now.
Network setup using Unifi hardware:
* Global settings for Gareway mDNS Proxy and IGMP Snooping : disabled/off
* VLAN1 (main - trusted) IPV4 192.168.10.x/24, IPV6 setup static, FDAA:x:x:0001::/64
* VLAN20 (family - trusted) IPV4 192.168.20.x/24, IPV6 setup static, FDAA:x:x:0002::/64
* VLAN30 (iot - untrusted) IPV4 192.168.30.x/24, IPV6 setup static, FDAA:x:x:0003::/64
* NO mDNS traffic allowed between VLAN30 and VLAN1
PVE setup
I am running my HAOS as VM on Proxmox PVE computers. HAOS is dual-homed to both VLAN1 and VLAN30:
untagged in vlan1: net0, bridge=vmbr0
tagged in vlan30: net1, bridge=vmbr0, firewall=1, tag=30
ZBT2 Antenna USB Device: host =####.####
:exclamation: My preferred setup is to connect USB devices to a dedicated RPI4 with Ser2net websockets to a VM. First I wanted to make sure Matter over Thread is working in HA.
added local conf settings to PVE in /etc/sysctl.d
net.ipv6.conf.vmbr0.autoconf = 0
net.ipv6.conf.vmbr0.accept_ra = 2
net.ipv6.conf.default.forwarding = 1
net.ipv6.conf.all.forwarding = 1
net.ipv6.conf.default.proxy_ndp = 1
net.ipv6.conf.all.proxy_ndp = 1
Matter devices in HA
To connect Matter, i am using a companion profile of:
Home Assistant URL: http://192.168.10.12:8123
Home Network: IOT network
Internal Connection URL: <empty>
and i have now 8 Ikea Matter devices connected :smiley:
CHECKLIST
This works but i am not fully done:
:white_check_mark: Setup HAOS for Matter Thread network
:white_check_mark: Connect ZBT2 to PVE host, HAOS VM. Autodetected in HAOS
:white_check_mark: Connect Ikea devices
:white_check_mark: Verify Matter and devices keep working after VM or PVE reboot
:heavy_check_mark: Adding new Matter devices works better after VM reboot.
:heavy_check_mark: Move ZBT2 connection from PVE + VM to a RPI with Ser2Net
:heavy_check_mark: Resolve connection issue (distance to Antenna?) of one device
