Matter with Eve Motion and Door&Window sensors information partly updated in HA
Dear all,
I have added four Eve sensors to my HA setup running on a Synology NAS in a VM.
Added first Skyconnect stick and then first one Eve Door& Window sensor => working great
Then added an Eve Motion detector => working great
Added another Eve Motion detector and an Eve Door&Window sensor, strange things are happening.
So not all sensor data is past through to HA. For example lux is not longer updates from Motion sensor but movement is still detected.
One Eve Door sensor is not updated in HA, but in Eve app this one is responding fast,
So all sensors and extra functionality is visible in Eve App and working but partly updated in HA.
What can I do?
Please advise?
many thanks in advance,
Frank
Matter sets an extreme strict template for the different type of sensors and there is no way to expand or change this.
This means if a motion sensor do not have a light sensor in the template, then there is no way to provide this sensor over Matter.
The same goes for smart plugs with monitoring. If they are converted to Matter, then they will smart plug without monitoring.
The Eve App does not use Matter, so it can still see all the sensors.
Hi Wally,
Many thanks for the swift response.
I see strange behavior.
One time all is working fine, but a few minutes later not all is working.
For example, a few minutes ago, my front door sensor was working fine in HA. Now the status is ‘Open’ while the door is closed. This is also the information in Eve App. The Eve App show always the correct status. Als changes, door open, closed is immediately visible in the Eve App. But unfortunately HA is not showing the same data ?!?!
So do you have any recommendations?
That I have no answer for, sorry.
