Matterbridge by luligu
Hi everyone :waving_hand:
I wanted to highlight a really powerful setup using Matterbridge together with its Home Assistant plugin — it’s one of the cleanest ways to expose Home Assistant entities to Matter ecosystems in a controlled and organized way.
For anyone not familiar, Matterbridge is a Matter plugin manager that allows you to bridge non-Matter devices into platforms like Amazon Echo (Alexa), Google Home, SmartThings, and other Matter-compatible systems — all locally and with great flexibility.
:wrench: What makes this setup stand out
With the Home Assistant plugin, you can control exactly what gets exposed:
  • Filter devices/entities by Area (rooms)
  • Filter by Label
  • Select specific entities by name / entity_id
  • Use include / exclude logic
This means no more dumping everything into your Matter ecosystem — you can keep things clean, organized, and intentional across all platforms.
:brain: Why it’s worth trying
  • Clean and clutter-free device sync across ecosystems
  • Full control over what gets exposed
  • Works locally (no heavy cloud reliance)
  • Great for multi-platform setups
  • Scales well even with large numbers of devices
:gear: Simple setup (Home Assistant OS)
For Home Assistant OS users, setup is very straightforward:
  1. Add the Matterbridge Home Assistant Add-on repository:
    https://github.com/Luligu/matterbridge-home-assistant-addon
  2. Install the Matterbridge add-on from the Add-on Store
  3. Start the add-on and open its Web UI
  4. Add and configure the Home Assistant plugin
    (connect via WebSocket — details here):
    matterbridge-home-assistant-addon/DOCS.md at e7a513db31497f68c16a4e878fc09d444e938429 · Luligu/matterbridge-home-assistant-addon · GitHub
  5. Configure your filters:
  • Areas
  • Labels
  • Entity names
  1. Pair Matterbridge with your preferred Matter platforms (Alexa, Google Home, SmartThings, etc.)
:light_bulb: Example use cases
  • Expose only “Living Room” devices to all Matter platforms
  • Share only lights or switches using labels
  • Keep internal or advanced entities hidden inside Home Assistant
  • Build a minimal, voice-friendly device set across multiple ecosystems
@tammeryousef I'm running into an issue I can't seem to solve. I've successfully installed the Matterbridge AddOn. Then I navigate to the WebUI and try to install plugins. I'd like to add the "matterbridge-hass". But as soon as I click on the "install" (from npm) button in the upper right corner. I get an error message in the lower right corner stating: "Installation of plugin "matterbridge-@latest" is blocked by the ignore list."
hi @Barungar , try to add dev version and see if its work for you ,
matterbridge-hass@dev then hit install
kindly share the screenshot to see whole home page when the error occured
Worked... thanks @tammeryousef
