PATBO
(Patrick Bonné)
August 25, 2019, 6:12pm
1
Hi
I have now used some hours to get HA to display MAX temperatures measured during the day.
I would like to reset every day at 20:00.
Min_max temperatures cannot be used because it combine the temperatures from more than one sensor.
The project: Monitoring the temperatures in the greenhouse.
I use an Sonoff SI7025 sensor with tasmota.
I use the statistics sensor for this over 24hrs - so it will span the days but generally, the daily minimum is around 6am and maximum in the afternoon so generally speaking it’s correct.
PATBO
(Patrick Bonné)
August 26, 2019, 4:03pm
3
How do you get the max_value out from the statistics sensor?
It’s an attribute - same as min
bom_today_max:
entity_id:
- sensor.bom_gosford_max_temp_c_0
- sensor.today_temp_bom
value_template: >
{%- if states('sensor.bom_gosford_max_temp_c_0') == 'n/a' -%}
{{ state_attr('sensor.today_temp_bom', 'max_value') }}
{% else %}
{{ states('sensor.bom_gosford_max_temp_c_0') }}
{% endif %}
bom_today_min:
entity_id:
- sensor.bom_gosford_min_temp_c_0
value_template: >
{%- if states('sensor.bom_gosford_min_temp_c_0') == 'n/a' -%}
{{ state_attr('sensor.today_temp_bom', 'min_value') }}
{% else %}
{{ states('sensor.bom_gosford_min_temp_c_0') }}
{% endif %}
- platform: statistics
sampling_size: 150
entity_id: sensor.bom_gosford_air_temp_c
max_age:
hours: 24
It only uses the statistics if the forecast value from my BOM sensor has disappeared (which it does after the minimum and maximum have been reached)
