Max values per tag limit exceeded - InfluxDB
I have ran into this issue where my log spits out the following error:
"error":"partial write: max-values-per-tag limit exceeded (100000/100000)
I get what it means and I’ve tried to follow advice from the article below
Max values per tag limit exceeded InfluxDB - Stack Overflow
But i’m missing the files that are required to change in this walkthrough
I’m running:
Home Assistant 2023.8.4
Supervisor 2023.08.1
Operating System 10.5
Frontend 20230802.1 - latest
Please advise, more information available upon request!
Thank you in advance!!!
Hello, sorry for replying for old topic but I’ve found how to solve that problem.
Settings → Addons → InfluxDB → Config → In Option section use three dot in right top and use Edit in YAML and add at the end:
envvars:
  - name: INFLUXDB_DATA_MAX_SERIES_PER_DATABASE
    value: "0"
