i created a MAX7219 text sensor that will display messages that i set with an automation in HA. But how do i make it act as countdown timer?
I want to have something ,like a button press, trigger the display to start a 20 minute timer. How would i do this?
The code in esp is the following and works fine:
esphome:
esp8266:
board: d1_mini_pro
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "bc0640266a6b34d9b87b69526e7e328a"
wifi:
ssid: "xxxxx"
password: "xxxxxx"
fast_connect: true
manual_ip:
static_ip: 192.168.2.50
gateway: 192.168.2.1
subnet: 255.255.255.0
ap:
ssid: "Ledmatrix Fallback Hotspot"
password: "1jvk6oluXVSh"
captive_portal:
spi:
clk_pin: D5
mosi_pin: D7
display:
- platform: max7219digit
cs_pin: D6
scroll_mode: stop
scroll_speed: 50ms
num_chips: 4
intensity: 8
lambda: |-
it.printf(0, 0,id(digit_font), "%s", id(led_matrix).state.c_str());
font:
- file: "pixelmix_bold.ttf"
text_sensor:
- platform: homeassistant
entity_id: input_text.led_matrix
binary_sensor:
- platform: status
