kb2ear
(Scott Weis KB2EAR )
September 28, 2023, 5:27pm
1
I have a simple clock on an ESP8266 running max7219 8 segment display. When I updated to the latest code last night the esp8266 no longer fully boots, the API is not accessable, the web server is not accessable. The clock does not display on the max7219 board any more. If I remove the max7219 display from the yaml the exp8266 boots and api and web server work again. Is this a new bug?
kb2ear
September 29, 2023, 3:06am
2
I’ve confirmed that it’s something in the 2023.9.0 update, I restored from backup to 2023.8.3 and recompiled and installed and my max7219 and other stuff are working again.
Any ideas?
zoogara
(Daryl)
September 29, 2023, 3:10am
3
There is an issue open on Github - I suggest you go there and add a me-too, plus it will be the best place to track resolution.
opened 10:09AM - 27 Sep 23 UTC
### The problem
After update from ESPHome 2023.08.3
One of my device goes down…
Device Unknow in HA at now
I can update ESP throw OTA wo any problem.
Then try to log wirelessly:
WARNING Can't connect to ESPHome API for 192.168.1.116: Error connecting to ('192.168.1.116', 6053): [Errno 111] Connect call failed ('192.168.1.116', 6053) (SocketAPIError)
After small investigation:
If comment this section:
display:
platform: max7219
cs_pin: D8
num_chips: 1
intensity: 15
update_interval: 1s
lambda: |-
it.print(0, id(display_data).state.c_str());
Afterthat ESP Api work good
### Which version of ESPHome has the issue?
2023.09
### What type of installation are you using?
Home Assistant Add-on
### Which version of Home Assistant has the issue?
2023.09.3
### What platform are you using?
ESP8266
### Board
d1_mini
### Component causing the issue
max7219
### Example YAML snippet
```yaml
substitutions:
device_name: temperature-display
device_ip: 192.168.1.116
platform: ESP8266
board: d1_mini
device_description: "Дисплей температуры и ppm в гостиной"
esphome:
platform: ${platform}
board: ${board}
comment: ${device_description}
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "J2+3oqEO6eDX0EleMvkLcTooGO0x2MaNFk+C/nFkRbU="
# Password for OTA update
ota:
password: !secret ota_password
# Wifi settings
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: ${device_ip}
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: ${device_name} ap
password: !secret ap_password
captive_portal:
spi:
clk_pin: D5
mosi_pin: D7
display:
platform: max7219
cs_pin: D8
num_chips: 1
intensity: 15
update_interval: 1s
lambda: |-
# # SENSOR AREA
text_sensor:
- platform: homeassistant
entity_id: sensor.livingroom_screen_data
internal: true
disabled_by_default: true
### Anything in the logs that might be useful for us?
```txt
INFO ESPHome 2023.9.0
INFO Reading configuration /config/esphome/temperature-display.yaml...
INFO Starting log output from 192.168.1.116 using esphome API
INFO Trying to connect to 192.168.1.116 in the background
### Additional information
_No response_
Protoncek
(Pavel)
November 28, 2023, 8:21am
5
Scott, can you share your yaml for this clock? I’m in a process of making such a clock, only with somewhat bigger displays…
