I’m after some advise - I am very new to HA and ESPhome.
I have several Maxico plugs converted to ESPhome, they are configured as per the ESPhome website:
substitutions:
device_name: "plug04-tv"
friendly_name: "Plug04-tv"
main_icon: "plug"
default_state: "RESTORE_DEFAULT_ON"
equal to
activity_threshold: "5"
# Basic Config
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "name"
password: "password"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
time:
- platform: homeassistant
# Device Specific Config
binary_sensor:
# Push Button (Toggles Relay When Pressed)
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: true
on_press:
- switch.toggle: relay
- platform: status
name: "${friendly_name} Server Status"
switch:
# Relay (As Switch)
- platform: gpio
icon: "mdi:${main_icon}"
pin: GPIO15
restore_mode: "${default_state}"
on_turn_on:
- light.turn_on:
brightness: 100%
transition_length: 0s
on_turn_off:
- light.turn_off:
# WiFi Signal Sensor
- platform: wifi_signal
name: "${friendly_name} WiFi Status"
update_interval: 60s
# Power Monitoring
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: true
cf_pin: GPIO5
cf1_pin: GPIO14
change_mode_every: 3
update_interval: 3s
voltage:
unit_of_measurement: V
accuracy_decimals: 1
filters:
# Map from sensor -> measured value
- calibrate_linear:
- 0.0 -> 0.0
- 602.87506 -> 229.9
- 609.8 -> 232.8
power:
unit_of_measurement: W
accuracy_decimals: 2
filters:
- calibrate_linear:
- 0.0 -> 1.14
- 62.06167 -> 10.93
- 1503.27161 -> 247.6
- 1599.81213 -> 263.7
- 3923.67700 -> 631.4
- 7109.50928 -> 1148.0
- 7237.0857 -> 1193.0
- 7426.71338 -> 1217.0
current:
unit_of_measurement: A
accuracy_decimals: 3
filters:
- calibrate_linear:
- 0.0 -> 0.013
- 0.08208 -> 0.071
- 1.34223 -> 1.066
- 5.57170 -> 4.408
- 6.69184 -> 5.259
- 6.97187 -> 5.540
# Total daily energy sensor
- platform: total_daily_energy
name: "${friendly_name} Daily Energy"
power_id: power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
text_sensor:
# Device Activity State
# e.g. shows as active if power reading above a certain threshold
name: "${friendly_name} Activity State"
lambda: |-
if (id(power).state >= $activity_threshold) {
return {"Active"};
} else {
return {"Idle"};
update_interval: 5s
# Relay State LED
output:
- platform: esp8266_pwm
pin:
number: GPIO0
inverted: false
light:
- platform: monochromatic
output: state_led
What I would like to add to this config is section where the LED would flash when the device is attempting to connect to wifi (or dropped of the network and reconnecting).
Can someone point me in the right direction please.
Andre
