Is there a way to block ip incase of maximum login attempt? i.e., Block user if there are failed login after few tries by a hacker…
Yes, under the http section of your configuration.yaml file:
https://www.home-assistant.io/integrations/http#ip-filtering-and-banning
http:
ip_ban_enabled: true
login_attempts_threshold: 3
Thank you Tom
