πŸš† MBTALive 2.0 – A Complete Overhaul!
I’m excited to introduce MBTALive 2.0, a completely rebuilt Home Assistant integration for tracking MBTA (Massachusetts Bay Transportation Authority) transit in real-time! :oncoming_bus::metro::ferry:
What’s New in 2.0?
:white_check_mark: Fully redesigned integration – more efficient, accurate, and reliable.
:white_check_mark: Now available in HACS – easy installation and updates.
:white_check_mark: Trip-based tracking – monitor direct trips from departure to arrival stops.
:white_check_mark: Supports multiple routes and lines – always finds the fastest way.
:white_check_mark: Improved real-time data – frequent updates for better accuracy.
:white_check_mark: Enhanced configuration – easily configuration from the UI
How It Works
  • Tracks two trips:
    • Current trip β†’ The next arrival at your departure stop.
    • Next trip β†’ The following trip, available in the next attribute.
  • Sorts trips by arrival time at the destination – prioritizing the fastest route.
  • Supports trains, subways, buses, and ferries with real-time locations.
Installation & Setup
:one: Install via HACS – Add https://github.com/chiabre/MBTALive as a custom repository.
:two: Restart Home Assistant.
:three: Add the MBTALive integration under Settings β†’ Devices & Services.
:four: Configure stops & MBTA API key – Get an API key here.
Why Upgrade to 2.0?
This release makes MBTALive more powerful and easier to use than ever. Whether you’re tracking your daily commute or monitoring transit conditions, MBTALive 2.0 gives you the most reliable and up-to-date information right in Home Assistant.
:link: GitHub & Documentation: MBTALive Repository
:rocket: Try it out and let me know what you think! Your feedback and contributions are always welcome. :blush:
This is fantastic! Excited to try this out over the next few days.
MBTALive 2.1 - Release Notes
:train2: Improved Trip & Train Tracking
  • Support for tracking specific Commuter Rail trains by train number.
  • Customizable number of tracked trips/trains (default: 2, user-configurable).
:gear: New Configuration UI
  • Streamlined setup process within Home Assistant.
  • Better validation for station names, train numbers, and API keys.
  • Tracked trips/trains can now be modified after initial setup.
:wrench: New mbtaclient Version
  • More accurate predictions for improved reliability.
  • Enhanced caching for better performance and efficiency.
  • Request retry mechanism to handle API failures more gracefully.
