McKesson Bed Sensor Pad Wiring
I picked up one of these bed sensor pads to see if I can get it to work with HA. The pad has a 4-conductor wire, red, black, green, and yellow.
Red and black always have continuity between them as do green and yellow. Pressure on the pad doesn’t seem to affect this.
Anyone out there used one of these before and/or able to shed some light on what readings I should be looking for with the multimeter?
I have a pressure mat that has 4 cables (all black) but I only use 2 of the 4 and they are just attached to an aqara leak sensor set in occupancy mode which works pretty much flawless since setting it up.
You just need to see what 2 of the 4 will allow a closed circuit when pressure is applied.
One of those wire loops is there exclusively to detect if the device has been cut (for alarms).
Still struggling with this one. I’ve got the four wires each hooked up to a GPIO on an ESP32 and the voltage readings don’t really give me any indication when someone’s in bed (see graph below).
Green/Yellow have continuity as do Black/Red. I’ve tried connecting G/B, G/R, Y/B, and Y/R and don’t get any significant readings across them with a multimeter when there’s someone in bed.
Anyone have a suggestion for a next step that’s not “Return the thing to Amazon”? :rofl:
You’re not supposed to be connecting those wires directly to GPIO. What you’re supposed to be making is a resistor network that allows you to sense voltage differences in the range of 0–3.3V and therefore measure the change in resistance.
Hang on…
  1. Find the two leads that have some sort of resistance that varies with weight using your multimeter (it should be high normally and drop down when squeezed hard).
  2. Then use those two leads as part of our resistor network, with a decent amount of resistance added in the network (in my case I used 460k ohm IIRC). I will share below my own sensor’s schematic.
Then you will have a sensor that will get you a variable resistance or variable voltage. When the resistance goes below a certain setpoint, that means detection.
On top of that you can add debouncing using the delay on and delay off ESPhome constructs.
Here is the schematic of my bed sensor:
Note the bed pressure sensors are VR1 and VR2.
Here is the YAML
substitutions:
  friendly_name: Master bedroom bed
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
esp32:
  # XTVTX ESP32 (wroom)
  board: nodemcu-32s
  framework:
    type: esp-idf
logger:
  level: debug
  logs:
    esp32_ble: debug
    sensor: info
    mdns: debug
    adc: info
    resistance: info
    internal_temperature: info
# Enable Home Assistant API
api:
  encryption:
    key: "<SUITABLE ENCRYPTION KEY>"
ota:
  - platform: esphome
    password: "<SUITABLE OTA PASSWORD>"
wifi:
  reboot_timeout: 120min
  networks:
  - ssid: !secret wifi_ssid
esp32_ble_tracker:
  scan_parameters:
    active: true
bluetooth_proxy:
  active: true
number:
    optimistic: true
    name: Resistance threshold for occupant 1
    min_value: 0
    max_value: 212184185438208
    step: 1000
    icon: mdi:omega
    entity_category: config
    unit_of_measurement: Ω
    restore_value: True
    optimistic: true
    name: Resistance threshold for occupant 2
    min_value: 0
    step: 1000
    icon: mdi:omega
    restore_value: True
binary_sensor:
    device_class: occupancy
    icon: mdi:bed
    lambda: |
      if (id(variable_resistance_1).state < id(resistance_threshold_for_occupant_1).state) {
        return true;
      return false;
    filters:
      delayed_off: 5s
#    on_state:
#      - if:
#          condition:
#            lambda: "return id(occupant_1).state;"
#          then:
#            - lambda: >
#                id(occupant_1).set_icon("mdi:bed");
#          else:
#            - lambda: >
#                id(occupant_1).set_icon("mdi:bed-empty");
    icon: mdi:bed
    lambda: |
      if (id(variable_resistance_2).state < id(resistance_threshold_for_occupant_2).state) {
        return true;
      return false;
    filters:
      delayed_off: 5s
#    on_state:
#      - if:
#          condition:
#            lambda: "return id(occupant_2).state;"
#          then:
#            - lambda: >
#                id(occupant_2).set_icon("mdi:bed");
#          else:
#            - lambda: >
#                id(occupant_2).set_icon("mdi:bed-empty");
button:
  - platform: restart
    entity_category: diagnostic
    icon: mdi:restart
  - platform: safe_mode
    name: Safe mode restart
    icon: mdi:restart-alert
- platform: uptime
- platform: wifi_signal
  name: "Wi-Fi signal strength"
  update_interval: 10s
  entity_category: "diagnostic"
- platform: internal_temperature
  name: "Device temperature"
- platform: adc
  name: Resistance voltage 1
  pin: GPIO35
  attenuation: 11dB
  accuracy_decimals: 5
  update_interval: 0.2s
  filters:
    - median:
        window_size: 25
        send_every: 5
        send_first_at: 1
    - calibrate_linear:
      - 0.142 -> 0.0
      - 3.171 -> 3.33
  disabled_by_default: True
- platform: resistance
  name: Variable resistance 1
  sensor: resistance_voltage_1
  configuration: UPSTREAM
  resistor: 462kOhm
  reference_voltage: 3.33V
  icon: mdi:resistor
- platform: adc
  name: Resistance voltage 2
  pin: GPIO32
  attenuation: 11dB
  filters:
    - median:
        window_size: 25
        send_every: 5
        send_first_at: 1
    - calibrate_linear:
      - 0.142 -> 0.0
      - 3.171 -> 3.33
  name: Variable resistance 2
  sensor: resistance_voltage_2
  resistor: 470kOhm
  icon: mdi:resistor
Thank you so much for that detailed reply. I finally had time to dig in to this and replicate your circuit (I think) and I’m not getting the results you describe.
I’ve tried with every permutation of the orange and brown wires with the R/B/G/Y wires from the sensor pad, but I think the yellow and green are the correct pair.
Regardless, the logs show the same values over and over, even with pressure on the sensor:
[12:10:04][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[12:10:04][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[12:10:04][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[12:10:06][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[12:10:06][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[12:10:07][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[12:10:09][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[12:10:09][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[12:10:09][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[12:10:11][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[12:10:11][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[12:10:11][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
Here’s my sensor config:
  - platform: adc
    pin: GPIO5
    attenuation: 12dB
    icon: mdi:bed
    update_interval: 0.5s
    filters:
      - median:
          window_size: 25
          send_every: 5
          send_first_at: 1
    resistor: 470kOhm
    icon: mdi:resistor
Any suggestions? Is my circuit even correct?
Did you first determine which pair of wires actually changes resistance with a multimeter?
You shouldn’t swim before you can walk.
Yes, the green and yellow pair changes resistance when I attach a multimeter and apply pressure to the pad.
Simplify.
  • Green lead to 3.3v.
  • Yellow lead to:
      • GPIO35 (or equivalent pin chosen in the ADC sensor of your YAML)
      • 460K resistance
  • Other side of 460K resistance to GND.
Skip the capacitors for now.
You should see the ADC value change up or down when you compress the resistance. It’ll be noisy because of no capacitors, but at least you can confirm it’s happening and you can add the caps later.
Also, what is the range of resistances your thing goes over? You may have to select a different resistance to get a good ADC measurement.
Unfortunately, nothing changes. During the esphome logs output below, I was applying various levels of pressure to the pad, up to and including my full body weight. Nothing changed.
[09:38:10][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[09:38:10][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[09:38:10][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[09:38:12][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[09:38:12][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[09:38:12][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[09:38:15][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[09:38:15][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[09:38:15][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[09:38:17][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[09:38:17][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[09:38:17][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[09:38:20][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[09:38:20][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[09:38:20][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
[09:38:22][D][sensor:093]: 'GPIO5': Sending state 3.10700 V with 5 decimals of accuracy
[09:38:22][D][resistance:039]: 'Variable resistance 1' - Resistance 33733.5Ω
[09:38:22][D][sensor:093]: 'Variable resistance 1': Sending state 33733.47656 Ω with 1 decimals of accuracy
When I hook the pad to the meter directly, it hovers around 1.2-1.3Ω unloaded. Adding weight causes it to drop to 0.8-0.9Ω, and as I remove the weight it goes up to anywhere from 3-4Ω. Over the next 30 seconds or so, it slowly settles back to around 1.2Ω.
Updated circuit photo just for verification/sanity check:
Thanks again for your help!
Oh my god, 0.8 ohms??? I am at a loss of how to measure that with a voltage divider network without frying the ESP’s pads. For all i know they might already be fried! If you connected it to the ESP, that would have caused 3.3+ amps or more to flow thru the pad, rated max for 0.02 amps.
Ok, then I’m just going to wait until the guy manufacturing the dual bed sensor gets some more made. I truly appreciate your time and guidance, @Rudd-O!
I was also trying to set up bed sensors. After getting some in the mail, I found out they’re the same thing as home Dance Mats. I bought some myself, wired them up, and found they were unreliable; sometimes working, sometimes getting stuck “pressed”. Might’ve just been the ones I bought, but each one was $43 USD! Those also had 4 wires, but I was only using 2.
I’ve been spending time trying to figure out if I missed anything and came across this thread (as well as many others). It’s possible I needed something more complex.
Using a large Capacitor instead
Because you guys were talking about measuring the resistance, I wanted to point out this guide I used:
It talks about using two pieces of aluminum foil on either side of a sheet of paper. You’re measuring capacitance without a special circuit. In my testing under couch cushions, it totally works! Haven’t tested with the bed just yet. Calibration is also very simple. Hardest part was filtering down results such that it wouldn’t go On-Off-On-Off-On a billion times.
I really thought it was a fake article because of how stupid it sounded: no fluff; no crazy circuit. You can do the whole thing in software, but you do need at least an ESP32 which has capacitance monitoring circuitry.
How do you monitor capacitance with ESPs?
There are only certain pins that do it. And then this:
binary_sensor:
  - platform: esp32_touch
    pin: GPIO33
    threshold: 5
    filters:
    - delayed_on: 50ms
    - delayed_off: 5s
