[{"id":"de44e696.38115","type":"tab","label":"Test fade","disabled":false,"info":""},{"id":"b9c7540b.8e8ee","type":"api-call-service","z":"de44e696.38115","name":"Mclighting01","server":"e6482986.08f318","service_domain":"light","service":"turn_on","data":"{ \"entity_id\": \"light.mclighting01\", \"brightness_pct\": \"50\", \"kelvin\": \"2500\", \"effect\": \"Static\" }","mergecontext":"","x":920,"y":100,"wires":[["9a55a6f1.56f5d8"]]},{"id":"1ed98919.1cdf17","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":100,"wires":[["b9c7540b.8e8ee"]]},{"id":"767c735f.660ef4","type":"api-call-service","z":"de44e696.38115","name":"Animation Speed 121","server":"e6482986.08f318","service_domain":"input_number","service":"set_value","data":"{ \"entity_id\": \"input_number.neopixel_animation_speed\", \"value\": \"121\" }","mergecontext":"","x":320,"y":40,"wires":[["855f14d5.f46a38"]]},{"id":"855f14d5.f46a38","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":80,"wires":[["3903e1fa.88070e"]]},{"id":"3903e1fa.88070e","type":"api-call-service","z":"de44e696.38115","name":"Mclighting01 Wipe","server":"e6482986.08f318","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.mclighting01\",\"kelvin\":\"2500\",\"brightness_pct\": \"50\", \"effect\":\"Color Wipe Reverse\"}","mergecontext":"","x":310,"y":80,"wires":[["85a93c47.db412"]]},{"id":"85a93c47.db412","type":"delay","z":"de44e696.38115","name":"","pauseType":"delay","timeout":"1650","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":520,"y":80,"wires":[["1ed98919.1cdf17"]]},{"id":"14a2595c.280da7","type":"delay","z":"de44e696.38115","name":"","pauseType":"delay","timeout":"1650","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":540,"y":280,"wires":[["ae89feb4.90fdb"]]},{"id":"d7e32f7f.c3089","type":"api-call-service","z":"de44e696.38115","name":"Mclighting01 Wipe off","server":"e6482986.08f318","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.mclighting01\",\"kelvin\":\"2500\",\"brightness_pct\": \"50\", \"effect\":\"Color Wipe Inverse\"}","mergecontext":"","x":320,"y":280,"wires":[["14a2595c.280da7"]]},{"id":"242233cf.a226bc","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":280,"wires":[["d7e32f7f.c3089"]]},{"id":"b1b62485.3ccd88","type":"api-call-service","z":"de44e696.38115","name":"Animation Speed 121","server":"e6482986.08f318","service_domain":"input_number","service":"set_value","data":"{ \"entity_id\": \"input_number.neopixel_animation_speed\", \"value\": \"121\" }","mergecontext":"","x":320,"y":240,"wires":[["242233cf.a226bc"]]},{"id":"ae89feb4.90fdb","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":280,"wires":[["609fe0db.bf70b"]]},{"id":"609fe0db.bf70b","type":"api-call-service","z":"de44e696.38115","name":"Mclighting01","server":"e6482986.08f318","service_domain":"light","service":"turn_off","data":"{ \"entity_id\": \"light.mclighting01\"}","mergecontext":"","x":880,"y":280,"wires":[["de7d937e.00fd"]]},{"id":"35fc91f8.9fd47e","type":"api-call-service","z":"de44e696.38115","name":"Animation Speed 181","server":"e6482986.08f318","service_domain":"input_number","service":"set_value","data":"{ \"entity_id\": \"input_number.neopixel_animation_speed\", \"value\": \"181\" }","mergecontext":"","x":1270,"y":280,"wires":[[]]},{"id":"91bef71b.9451e8","type":"mqtt in","z":"de44e696.38115","name":"nodered/lights/kitchen","topic":"nodered/lights/kitchen","qos":"2","broker":"1e65ba18.744ec6","x":120,"y":180,"wires":[["6996f096.8b768"]]},{"id":"6996f096.8b768","type":"switch","z":"de44e696.38115","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"fade up","vt":"str"},{"t":"eq","v":"fade up slow","vt":"str"},{"t":"eq","v":"fade down","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":290,"y":180,"wires":[["767c735f.660ef4"],["5f316d88.04f564"],["b1b62485.3ccd88"],[]]},{"id":"5f316d88.04f564","type":"api-call-service","z":"de44e696.38115","name":"Animation Speed 11","server":"e6482986.08f318","service_domain":"input_number","service":"set_value","data":"{ \"entity_id\": \"input_number.neopixel_animation_speed\", \"value\": \"11\" }","mergecontext":"","x":520,"y":180,"wires":[["7f69a358.5919cc"]]},{"id":"7f69a358.5919cc","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":180,"wires":[["a1954233.dbc98"]]},{"id":"18ecbd63.7237e3","type":"api-call-service","z":"de44e696.38115","name":"Animation Speed 181","server":"e6482986.08f318","service_domain":"input_number","service":"set_value","data":"{ \"entity_id\": \"input_number.neopixel_animation_speed\", \"value\": \"181\" }","mergecontext":"","x":1330,"y":100,"wires":[[]]},{"id":"a1954233.dbc98","type":"api-call-service","z":"de44e696.38115","name":"Mclighting01 Wipe","server":"e6482986.08f318","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.mclighting01\",\"kelvin\":\"2500\",\"brightness_pct\": \"50\", \"effect\":\"Color Wipe Reverse\"}","mergecontext":"","x":900,"y":180,"wires":[["92b5867c.a84c78"]]},{"id":"92b5867c.a84c78","type":"delay","z":"de44e696.38115","name":"","pauseType":"delay","timeout":"23","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1090,"y":180,"wires":[["cdf941dc.2b0dd"]]},{"id":"cdf941dc.2b0dd","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":180,"wires":[["b9c7540b.8e8ee"]]},{"id":"9a55a6f1.56f5d8","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1120,"y":100,"wires":[["18ecbd63.7237e3"]]},{"id":"de7d937e.00fd","type":"change","z":"de44e696.38115","name":"Set to Blank","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1060,"y":280,"wires":[["35fc91f8.9fd47e"]]}]
This is my first export, so hopefully i’ve removed my server bits.
So basiclly i use MQTT to fade up and down, which really calls a animation and sets the speed for a set amount. I know it takes 15 seconds for the sweep effect at speed y to light them all on, i counted.
Same for off.
