MCO Home Tehrmostat via Home Center Lite
Hello
I got a Home Center Lite to managed my Z-wave devices. It is integrated with my Home Assistant.
Most of the things are working ok, however I got a problem with my Z-wave thermostat from MCO Home - MCOEMH7H-EH2. It does work fine in Home Center Lite - I can change operations mode, target temperature etc.
Using standard integration with Fibaro Hub I got all devices into Home Assistant.
Unfortunately in Home Assistant I am not able to change the operation mode of my thermostat.
MCHome2 Always if I try to change operation mode to Auto or Off after 1 second it switching it self to the Heat mode back.Same things is happening if I change preset to Away, but this time operation Auto is always selected - even if I change it to Off or Heat - after 1 second it will be changed to Auto.
Any idea what is going ?
Thx & Regards
If this is still an issue, please enable debug level logging for the fibaro and fibaro.climate components and post the relevant log information. What would be interesting is the device readout in the beginning when the system boots up and the logs of communication as you switch it.
Hello Peter
sorry for being so late on this one, but yes I have still the same problem.
I will generate the logs and let you know. Thx & Regard
